Question about Cooktops
How to replace the ignition switch for a Creda GGH 102
Plastic 'lever' that is pushed down by Knob is broken
2 Suggested Answers
SOURCE: Looking for new spare parts Creda Gas cooktop 42320
Contact this gentleman: Sandor Horky shorky@adcoservice.com
He helped us with parts we needed for our CREDA Model GGH110. I believe the company ADCO is the after market people for CREDA. Good Luck. PA Fi.
Posted on Mar 18, 2009
Hello, My Creda cookertop ignition system has a problem . There are 4 burners on this CT. 2 diagonally across burners cannot ignite when their knobs are activated but they show sparks of ignition when the...
(1) Get Naval Jelly (Rust dissolver) and apply on the igniter and than see if everything is fine.
(2) Check the connections from the knob to the burner. Probably have a leak. Replace the wire from the knob to the burner.
Feb 02, 2011 | Cooktops
Have Jenn-Air 36" gas cooktop w. 5 burners, black. Mdl JGC8536ADB. Plastic knobs keep splitting, even if we remember to push down before turning. Have replaced two sets and now we're down to two working...
Hi
Thanks for using FixYa. There are a few things to check for. Make sure the electrode (the small metal piece that the spark comes off from) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and not a tooth pick as these can break off and make things worse. Example of a burner. The next thing to check for are the ignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it.
The switches or the range control knobs may have got wet and are completing the circuit to the spark module thus causing it to continuously click or fire off sparks continuously. Use your hair/blow dryer and blow some hot air around the spark module area.
This is a typical spark module wire diagram--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 31, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Mar 12, 2009 | Cooktops
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
SWITCH KNOB
Pull off the knob and then see if you can push the shaft in. If you can, then the knob is hitting something, preventing you from being able to push the knob in. Adjust the knob until you can push it in. If you can't push the shaft in with the knob off, then the control valve is broken and you will have to replace it.
Sep 03, 2008 | Miele 35 in. KM326G Gas Cooktop
I need a user manual
I need access to the spark plug module for replacement. The plastic stove top seems sealed to the metal housing. How do I gain access? Creda GH 102 series cooktop. Spark Module Replacement.
Apr 15, 2008 | Cooktops
Burner with intermittent feature won't light once hot; spart OK - - no gas.
mdpaul, sounds to me like 1 of the burner switches for the ignition is sticking. There is a small area where the switches turn to that shuts down the ignition. If the switch has failed from heat or is out of position, this can cause this issue. The switch is designed so when you turn the knob it closes the contact. The switch has to be locked into postion on this model. There is a push fit type retainer that locks this down. Pull the knobs off and turn with a pair of plyers to see if one is moving around. If so then with a deep socket, see if you can tighten the retainer by pushing down on it. Hope this helps.
Feb 03, 2008 | Thermador SGS36GS Gas Cooktop
Cooktops Logo
63 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
