Question about Tascam CD355 5Disc CD Changer
I HAVE A TASCAM 355 CD PLAYER AND IT WIL NOT PLAY CDS I'M GETTING A TOC READ MSG. HOW CAN I FIX IT?
mjap
  • 107 Answers
SOURCE: cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Posted on Jan 30, 2008
SOURCE: cd rewritable player recorder tascam cdrw4u
I never had that problems. I have been using it over five years. Does it play commercially made CDs (the ones you bought at the store)? Panel shows track numbers and sound volume? Can you hear it by using a head set (phone volume control turned up? If so, now recording part, do you have input select correct (analog or digital)? Input cable(s) into right connector(s)? When you press "record" button, does it put into "pause" mode? Can you watch the incoming sound levels when it is on "pause" mode? Can you start the recording with remote's fader button or play/pause button on the machine? Good luck.
Posted on Jun 18, 2008
SOURCE: Tascam CD-A500 'no disk' problem
How hard is it to replace optical lens on the Tascam CD-A500?
Posted on Oct 14, 2008
gothtaz
  • 3 Answers
SOURCE: tASCOM cd a500 - DOES NOT READ DISC
There is one of two things that is wrong with it..
1 the laser lens is dirty and needs to be cleaned witch you can fine a laser lens cleaner at your local radio shack.
2 the laser lens could have been bumped off the track so is that is the case you will have to poen it up and use something soft like a Que tip and gently nudge it.
Posted on Oct 16, 2008
projdoc
  • 2237 Answers
SOURCE: cd player ejects will not play
can't read the disk. either the disk is dirty or the lens on the optical pickup is. get a lens cleaner disk from any electronics store.
Posted on Jan 15, 2010
My tascam is starting to eject most cds I try to play. These are cds I have always been able to play plus new ones. I haven't had problem recording on it.
There are a number of things that can cause a CD not to read and then be rejected. It can be dirt accumulated on the lens, lack of correct spin up of the spindle motor- they often times need good oiling and then maybe the deck does not know the tray is in due to a faulty switch. The questions are does it focus, does it spin up to proper rate and will it read the TOC?
Oct 25, 2016 | Tascam Audio Players & Recorders
Tascam CD-RW700 Not Working
Mine is doing the same thing. By pluging and unplugging the power back and forth sometimes I get it to read the disc and it stays on. If you get yours going then I suggest always leaving it on. It doesn't draw much. A temporary solution until you figure out how to fix it.
Apr 22, 2013 | Tascam Cd-Rw700
Cd player will not play cd's. Error code: TOC ERR
A few things it could be:
No disc has been loaded in the disc magazine.
CDs being used are burned, test using different media or an actual CD.
Very dirty or scratched CDs.
The CDs are upsidedown.
Sep 21, 2011 | Kenwood KDC-MP4028 CD Player
CD player does not recognise some CDs. When placed in the drawer the deck displays "no disc" if another CD player is used the disc works fine
I have two of these Tascam CD-A500 players, and one more than the other has this problem of not reading some CDs that will play fine in other players. I'm starting to loose faith in this Tascam product. Anyway, seems the consensus is to open it up and check for dirty laser optics. If that doesn't fix the problem, then send it in for repair or scrap it and buy a different brand. I've not had this problem with any other brand CD player, but very suspicious that the same problem happens on BOTH of my Tascam CD-A500 units.
Nov 15, 2009 | Tascam CD-A500 CD Player
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
Philips dvp 3020
This is usually caused by a faulty laser.
Most DVDs have two lasers. One for DVD & one for CD.
Sounds like the CD laser has failed.
Jan 19, 2008 | Philips DVP3020 DVD Player
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
TOC error
toc stands for table of contents error if it is a copied cd it is probably how it was written if not do other cds work?
chris
Oct 29, 2007 | Kenwood KDC-8024 CD Player
Tascam CD355 5Disc CD Changer Logo
49 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
