Question about Intel D945GCZLKR (BLKD945GCZLKR) Motherboard
After installing HIS 2600xt video card, computer will not boot
I wanted to upgrade from ATI 9600 to HIS 2600 xt. They both wotk via the agp slot. The HIS requires a power connection as if it were a drive. I uninstalled the old card and its drivers. I put the HIS card in and the machine will not boot. Starts to power up and red lighton the case stays on and nothing happens, not even powere to the keyboard or mouse. I am using a 400 watt power supply, pc 400 mobo, p4 1.6 processor. I tried clearing cmos and flashing bios, dowloading new drivers, nothing. I pop HIS card and insert old ATI and it fires right up no problems. Is there possibly a jumper have to be changed when you use a powered video card? Does anyone have any thoughts on this. I am ready to return the HIS card where I purchased it.
    Sergeant:
  • 192 Answers
I'm surprised that you can get this car into the slot, since from all I can find, the HIS 2600 xt is a PCI-E card and not AGP.
In some cases, there is just a compatibility issue and since the MB manufacturers have moved to PCI-E from AGP, there are fewer options for new cards.
Take it back and see if oyu can find a different card that will work wiht oyur motherboard.
Posted on Jan 10, 2009
I want to get a new graphic card this is my current one which graphic card would work for my desktop
Hello
OK, this question is actually dependent on a couple of factors. Let me explain:
How much are you willing to pay for an upgraded card?
Since the card is a PCI express card, you will be able to buy a compatible PCI express card as an upgrade.
Also, do you want to stick with ATI, or are you open to Nvidia as well?
Let me know, i will gladly assist.
Kind regards
Lock123
Feb 14, 2011 | ATI RADEON 9200 Graphic Card
I have no display after installing a radeon x800
Make sure you install your drivers for the new graphics card before you actually put it in.
May 13, 2009 | ATI Radeon X800 XT Mac Edition AGP Video...
VIA CPU to AGP Problem with 3Gb and Vista
Chances are good that your third 1gig memory module is faulty. Windows blue screen of death at startup is a typical symptom of faulty RAM memory.
Try replacing the third 1gig DIMM with another of the same type.
Let me know if this works or not.
Regards,
Graemevm
Apr 22, 2009 | Abit IP35P Motherboard
Hello there I have a P4 2.66 intel D845GRG chipset 2gig Ram and would like to upgrade my MSI GeForce4 MX440 Video card, I play CS1.6 online and would like to improve video quality and performance
Well the board and chip are fairly slow...
But... not too slow... so you can buy a new graphics card..
Luckily for you, the AGP slot cards have not completely disappeared off the face of the earth yet, and you could buy a cheap used one or even a new one if you like to waste money on old computers.
I suggest a 6600GT used or something similar.
try to get a 6 or 7 series or decent radeon 2900 or 2600xt or 3850 if you really want to blow the cash.
BUY AN AGP BOARD!! do not buy a PCI-Express board, as it will not plug into your motherboard.
Also check if you have an AGP slot before you buy a board.
Mar 13, 2009 | Intel Motherboard
Ati radeon 9550 agp with pinnacle pctv hd problem please help
Try to put it on another pci slot. if you are using the one right under the agp, then that is your culprit.  the agp and the top pci slot share video resources.  just put it on another pci slot, if you have to swap another non-video related card to the one just beneath the agp slot.  Hope this helps.
Mar 07, 2009 | ATI Radeon 8500 64MB AGP DVI/CRT/SVID...
IBM Thinkcentre m50 video card
Hi, i'm getting an ATI Radeon 2600XT for this system soon. But any AGP card *should* work fine (i'm hoping), just stick to midrange cards due to the low-grade power supply. I will post after the install and let you know how it goes.
Jun 21, 2008 | IBM ThinkCentre M50 Refurbished Intel...
ATI 9600 xt problems
Hi, Im guessing that your motherboard has an intergrated video card & you installed the 9600 card into the opened AGP slot on the board. If you would have listed the model number of your motherboard I would't have to guess. What you need to do is enter your bios & make a change so your bios loads the AGP slot & not the intergrated video card. How to get into your bios? As soon as you turn on the Pc press the Delete key every two seconds. If your system fails to load the bios than you will need to try some of the others F keys. Let the PC finish loading. Re-start the PC. As it starts up try the F1 key every two seconds. Continue in this manner using these other F keys untill your system boots into the bios. F2, F10 or F12. One will work for you. Once in the bios use your manual if you have one. You are looking for Video display. You want the bios to load the AGP slot first, this will disable the intergrated video automatically. Your Pc will now see your 9600 video card & you will be able to load it's software. If the 9600 uses ATI's software you should update the Radeon software by going to ATI/AMD & update your video software with the latest drivers. Click the link I have posted below to upgrade your Radeon 9600XT card. Good idea to save the link.
http://ati.amd.com/support/driver.html
Fill in the needed information to get to your driver software.
If your using Win XP Pro or Home click here:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
Feb 19, 2008 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Sapphire HD 2600 XT Driver Problems
To get your drivers follow these simply steps below:
First go to this website "CLICK HERE" - once you've done that fill in all the details of your "Graphics Card" then download them.
After you've completed the installation restart your computer just to make everything work correctly.
Note: after you've installed the driver your resolution when you've restarted your computer will be diffrenrent and may need changing.
Good luck. Hope my solution was helpful in someway. Further problems of any kind just leave a message on here and i will get back to you a.s.a.p.
Dec 02, 2007 | XFX NVIDIA GeForce 8600 Graphics Card
AGP ATI Radeon 9600
Much depends on what you want to spend and what you do with your Mac.
Here are some offerings for Macs:
http://eshop.macsales.com/Catalog_Page.cfm?Parent=67&ref=Google%20G5%20AGPVideoCards%2012175&title=Video%20Cards%2C%20Adapters%20%26%20KVM%20Switches&gclid=CLm-wp3W4I8CFQSOFQodeSrwCg
This discussion may help you decide which might be best for you:
http://forums.macnn.com/65/power-mac-and-mac-pro/322702/upgrading-my-g5-video-card/
Nov 13, 2007 | Apple ATI RADEON 9600 XT for Macintosh G5...
Intel D945GCZLKR (BLKD945GCZLKR) Motherboard Logo
76 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
