Question about Yamaha HTR-5940 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Must have hit a wrong button by accident but I have been looking for hours now to correct can anyone help--speakers are working when I test and works on movie mode but not on 6 channel stereo mode
  • 336 Answers
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Posted on Jan 10, 2009
Cant get volume on HP probook, kids hit some button on accident, everything shows volume is on but no sound
Check your laptop for a speaker icon on one of your keys, mine is on the Esc key, once found press the Fn key and hold, now press the key that the speaker icon is on and sound should be restored.
Mar 20, 2012 | HP ProBook 6540b Notebook
We have a Jensen marine system that came installed in our Tahoe boat. Shortly after we got the boat, the left speaker stopped working. A few months later, the speaker came back. Then just before the end of...
This really sounds like a wiring problem. I would start from scratch, seeing as how it will be difficult to find the issue you describe. Also, if you can, solder your connections to the radio. If you used crimp butts they may not have been tight enough and vibrated loose with use of the boat. Hope this helps
Sep 04, 2011 | Jensen Car Audio & Video
I was told i might have a fuse blown on my htr-5940,cause the 3 left speakers work for the test but not for actual playing.is that the problem?and where can i find the fuse?
There's no separate fuse for test versus operational speaker function.
Evaluate the source for why the "3 left" speakers (whatever that means) don't work for program material.
Jun 27, 2011 | Yamaha HTR-5940 Receiver
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
What could be causing the power to cut out on our HTR 5940 receiver
somewhere along the way something is shorting out.
First I would check the impedance of your speakers most common are 8ohm speakers and these can be driven by most amplifiers.
Some brands of speakers are 4 ohm and even less are 2 ohm. These lower resistance speakers put a great deal of strain on most amplifiers and may cause them to go into "protect" mode and temporarily shut down.(less resistance requires more ampsrage to drive them)
Next thing to check is to make sure that none of your speaker wires have any loose strands that may be shorting out either at the speaker terminals on the amplifier itself but also behind each speaker.
Another test would be to connect 1 speaker at a time and turn the volume up to see if perhaps the short is being caused by 1 particular speaker or 1 particular channel for example it may be your front left amplifier that is failing causing the entire system to shut down.
If you can't diagnose the problem on your own you may have to have a service tech look at it. I always caution people to first establish a "value" on any item that may need repair and then decide the maximum amount of money you would invest in repairing the unit Taking into consideration that 1 hour of labor and a relatively inexpensive part can easily add up to $100 to $150.
In the past when I have had similar issues it usually came back to being something basic that we overlooked in the installation, Ie: a bad cable loose connection etc.
Jan 01, 2010 | Yamaha HTR-5940 Receiver
Speakers quit working
Try hitting the mute button, you might of hit the mute button by accident.
Nov 11, 2009 | Dell Computers & Internet
Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
May 03, 2009 | Yamaha HTR-5630 Receiver
No sound on coming out of speakers and theres no wires touching everything looks like it works fine
Make sure you didn't accidentally hit the mute button.
You should always test sound with a CD, testing sound via AM/FM will produce interference and almost no sound when between stations, also don't to forget to connect the antenna lead.
Check that the speakers are wired correctly.
Check that the sound controls are adjusted properly, i.e. Balance, Fade etc.
Good luck...
Feb 24, 2009 | JVC KD-G210 CD Player
Want to connect my RCA sub to my yamaha htr-5940 reciever
Subwoofer needs to be enabled through menu on Yamaha. LINE OUT might be turned off or Subwoofer volume set to low or off... (-db level) kinda thing...speaker wires are usually always live etc...
Feb 03, 2009 | Yamaha HTR-5940 Receiver
Yamaha HTR-5940 Receiver Logo
262 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
