Question about Kirby G4 Bagged Upright Vacuum
Shampoer will not despenise the shampoo - Kirby G4 Bagged Upright Vacuum
  • 357 Answers
PLEASE SEE MY SHAMPOOER INSTRUCTIONS AND FOLOW THEM EXACTLY. IT SHOULD SOLVE YOUR PROBLEM...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
HOPE THIS HELPS!! :0)
MARCI
Posted on Jan 29, 2009
Can I use Rug Doctor steam cleaner shampoo in my Ultimate G series Kirby carpet shampoo system?
The answer is no. This type of shampoo doesn't work as well in the Kirby. It should be dry foam shampoo only.
Nov 20, 2010 | Kirby Ultimate G Bagged Upright Vacuum
ROLLER BRUSH NOT WORKING (BISSELL POWERSTEAMER PRO DELUXE )
The belt may be broken. Follow the link below to belt inspection video on www.bissell.com.
http://www.bissell.com/VideoRating.aspx?id=1555
Oct 05, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
How do you pick up the suds after shampooing
After dispensing the shampoo. You wait a few minutes. Then you turn 'off ' the shampoo picking the shampoo up. After the carpet is dry you pick up the rest. With the power head.
Oct 19, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G3 shampooer
The Kirby shampoer lays a layer of dry foam on the surface of the carpet and then scrubs it back off with a rotating brushroller. You can get more details of how to use one here...
Here is a step-by-step guide to help you out!!
Hope this helps,
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Bissell steam cleaner will not spray shampoo
My Bissell stops releasing shampoo when the handle is lacked upright, when there is no water in the tank (the most common cause of this issue), or when water is not flowing through the machine because the sprayers are clogged.
Make sure the shampoo container grommet is releasing properly when you press the trigger. To check this, remove the shampoo tank from the Bissell, stand over a sink, and use a finger to push up inside the grommet on the shampoo container, the part of it that mates with the rest of the Bissell. Shampoo should dribble out when you do this. If it won't, the grommet may be clogged.
May 29, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
How to shampoo stairs
HERE is the manual
When rating my solution rate the clarity of the explanation NOT whatever you like Kirby stair shampoo system. I do not believe this is the way to shampoo either but this is not me who designed it. Will get the job done but it is a lot of scrubbing and rubbing.
Good Luck
Rocky
Mar 24, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate D and Zippbrush
The zippbrush and shampoer are two different attachments. The Zippbrush is a small hand held device that is basically a rotating cleaning head that attaches to the hose. Connect it to the hose and the airflow starts turning the brush head, when it's running you'll hear a "zipping" sound.
Jul 08, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
87 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
