Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Fridge Light - you posted
Bobz,
Not sure if you got my last comment - I pulled the switch, but couldn't cross wires. If I unscrew the bulb, other electrical works fine/no buzz. Freezer works fine regardless of bulb in fridge. When you open the fridge with the bulb screwed in, it buzzes and the light flickers dimly, other electrical of fridge goes out (filter and cool setting numbers).
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Your bulb is shorted out internally. Try another bulb. Please post as as helpful if so.TY
Posted on Jan 10, 2009
Light inside fridge
unplug from power unscrew the bulb pull the bottom bulb contact out slightly replace the bulb plug in and, test
otherwise replace the bulb
Nov 18, 2013 | Furniture
Wired photo cell problem only 6 month old
Make sure that the white goes to the neutral, black to the live and the red to the load (light bulb). Make sure that the bulb is not hitting the socket before making electrical contact. Many bulbs these days get too fat too fast to screw down far enough. Cross the red and white to verify that it turns on. Make sure that the cadmium cell is not facing a light source preventing it from turning on at night etc. If so cover half of it with black electrical tape or create a sheet metal shield of some sort. Make sure there is not another timer or switch indoors that is now in the off position etc.
Mar 16, 2013 | Carlon Home Products Wired Photo Cell Post...
How to replace fridge lite bub
Fridge light bulbs unscrew just like the ones in the back of your stove. Depending on make and model you may have to remove some light covers to access the bulb to unscrew it. Can you locate the model of the fridge and post it here so I can help you better with a percise answer?
Sep 23, 2012 | Refrigerators
Trying to change upper light bulb in fridge
Make sure you unplug fridge from wall power socket,remove bulb cover if one is fitted.Carefully twist or gently try to unscrew bulb. If successful take bulb to electrical parts shop and buy a new one.You may of course use your Fridge until you buy a new lamp,Refitting is simply the reverse of removing bulb.Good Luck!
Nov 23, 2011 | Refrigerators
How do I get the light bulb out - does it unscrew or just pull straight out
It depends on the model.In some model you have to unscrew it.In most model you have to unscrew it only.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Jan 02, 2011 | Refrigerators
Tail lights not coming on. wiring problem
Replace the light switch, if I am right the dash lights will be out, if this is the case post back here to give you detailed instructions on how to fix. Thanks for using fix-ya.
Avid101
Aug 23, 2009 | 1996 Chevrolet K1500
Light keep on flicking on and off
Unplug the frig to remove power. Unscrew the bulb. Check the nub on the bottom of the bulb to make sure it is not flattened. Use needle nose pliers to grab the center tab of the bulb socket and pull outward slightly so bulb will make better connection. Could be a faulty switch or bad connection in the wiring.
May 29, 2008 | Refrigerators
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Light bulb replacementR
A fridge light bulb is usually a 40 watt appliance bulb with a screw base. It is heavy duty to last in the temperature. If it is not easily accesible to unscrew and replace, there may be plastic cover to unsnap.
Dec 27, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
171 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
