Question about Dishwashers
Jenn-air DW730B under counter dishwasher. Is there a filter that we need to clean and if so, how do we get to it
2 Suggested Answers
  • 145 Answers
SOURCE: Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
Posted on Apr 23, 2008
I have a Jenn Air dishwasher and the door latch mechanism has been "locked" but teh door is in the open position, how do I unlock the mechanism. I have pushed the het button three seconds but this me
This happened to me. After replacing the board for $100, still happened. I messed with it myself... Reach under the counter to where the "catch" is. Mine is white plastic. Mine had a bit of movement side to side (like 3mm). Try sliding it to one side or the other and see if the door will shut. I spent $100 I did not need to spend and hand washed dishes for 6 days waiting for the part! Good luck
Jan 05, 2013 | Jenn-Air 24 in. JDB1100AWS Built-in...
Knob on jenn aire under counter oven fell off. I lined it up and put it back on but it spins 1/8 of the way before it works. It doesn't look broken.
THere is a pin in the middle of the PLASTIC knob that probably broke off. It is not your fault, just cheap construction. Order the part, you have the code!!
Dec 27, 2012 | Jenn-Air Maytag Range Oven Burner Knob...
Jenn-air quiet series Model JDB8910AWW Dishes seemed to wash OK, but did not rinse. There is water (soapy) in the bottom. What do I do?
It is likely the drain function did not work.
Empty the dishwasher and clean the filters at the bottom. You will need a small container to empty the water and also use a towel to soak the remaining water.
If cleaning the filters does not help then there may be a blockage in the drain hose (check the kitchen sink side also). You may want to also confirm if the drain pump is operating at the right time in the cycle.
you could refer to this diagram for the parts involved.
Good luck.
May 13, 2011 | Jenn-Air 24 in. JDB1100AW Built-in...
My jenn aire dishwasher sounds like it is chewing up rocks
You might have something in the drain pump. To check you need to pull it out from the counter and remove the hoses from the pump to see. First turn off power to it, and make sure you have enough slack in the water line to pull out
Mar 23, 2011 | Jenn-Air JDB6510 Built-in Dishwasher
DOES JENN AIR HAVE A REST BUTTON, MY DISHWASHER WONT START. MODEL NUMBER JDB4000AWS
first of all if its a built in dishwasher under counter by the sink,check for a switch as you may have inadvertentally switched this switch off or unknowingly bumped it with something under the sink,then if it has power to the unit,there is a built in fuse on the control board
Nov 26, 2010 | Jenn-Air JDB4000AWS Stainless Steel...
JENN-AIR Model number JD3B10AWX. Bottom of dishwasher is dirty, I want to clean it. I have removed six screws holding plate down, but cannot find any way to remove spinning blade. I think there's a...
We have been having issues with our model where there is dirty sand deposited inside of glasses and dishes.
You need a torque wrench for a triple square torque screw82782a1.png to unscrew in the bottom filter to take it off.
I would say about 4-5 layers of items to remove- but remove these and clean them out as well as the top blade which should pop right out. Food particles can get stuck in there also.
Jul 28, 2010 | Jenn-Air Dishwashers
I have a Jenn-Air diswasher. I don't think the water is shooting out of the spinning arms. Is there something I can do to fix it?
yes mam please check the water pressure and remove the inlet hose and clean the inlet water filter then clean the arms.
Nov 10, 2009 | Jenn-Air 24 in. JDB1080AW Built-in...
After the dishwashing cycle, most of the soap tablet is lying in a mess inside the tub and the dishes are unwashed. This is a Jenn-air Quiet series dishwasher
hELLO THERE:
I would recommend first cleaning out all of the filters including the ones under the sprayer arms than i would check the pressure of the water going thru the system refer to the users manual or go to the manufactures website and view the pdf manual for troubleshooting
ok?
best regards michael
Sep 14, 2009 | Jenn-Air Dishwashers
JDB1100AWS not rinsing
if your filter assembly is clogged you are going to need to clean it. if it is really bad then it should be replaced. the part number is 99003292 and would probable cost about $30. the other thing is start your dishwasher on a rinse cycle and see if you have suds in the bottom do not put additional detergent in while checking this. if you have suds run vinegar in the dishwasher to help get rid of the suds as that can cause the same problem. Let me know if you need additional info
Jan 11, 2009 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn air quiet series II dishwasher has blinking light on clean and light wash after it runs...it only goes away when we push the off button...it didn't used to do this
Couple of things to check: there's a float that needs to more freely, make sure it does. There's dishwasher cleaning instructions in the operation manual. You may need to take the lower rack out, take off the spray arm to get at a filter, which you should clean and replace. Then you can try to run some white vinegar through a wash cycle. Jean Air has these instruction at their web site.
Oct 05, 2008 | Jenn-Air Dishwashers
Dishwashers Logo
Top Dishwashers Experts
