NAD L70 stops reading DVD - need DVD unit replacement, also 50 HZ noise comes to speakers
My NAD L70 became more and more sensitive to DVD disks and one day stops reading any DVD disk. I had open it and found some cracks in DVD unit - needs DVD unit replacement but where can i get spare parts? Another problem (independent from previous one) - once upon a time 50 HZ noise starts coming to speakers and even to SUB channel.
  • 899 Answers
SOURCE: disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Posted on Jan 15, 2009
ginko
  • 19396 Answers
SOURCE: dvd player wont read disk
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Posted on Apr 07, 2009
  • 586 Answers
SOURCE: Panasonic DVD-S35 Player H02 problem
    This problem is related to OPTICAL BLOCK ASSEMBLY. Two things are involved in this situation.
1- sleg motor start malfunctioning.
2- Optical Lens problem.
In both situations you have to replace the OPTICAL LENS BLOCK.
Therefore your DVD need lens replacement. And it would work fine again.
Thanks for using fixya.
Posted on May 31, 2009
SpideRaY
  • 687 Answers
SOURCE: Unknown disc error and whirring sound!
Do you leave the unit on all day and night on standby?
If this unit gets to hot you can experience this problem I suggest that you turn the power OFF totally until the unit cools down and try again. Normally 15 mins is enough.
Posted on Sep 24, 2009
SOURCE: error reading any dvd disks
Hi, I am facing similar problem when I inserted DVD into my player. Motor spins for a while and stops then after. I removed top cover and moved it manually when it stopped, but no luck. My system is able to play all other disks like VCD, DATA CD, AUDIO CDs, but not DVD. It was working fine just few days back. Don't know what could be the reason. any body can halp me. my warranty period got expired.
Posted on Jun 14, 2010
What should i set the micro switch on the back at?
Power:
2 ohm stereo (per channel): 975W
4 ohm stereo (per channel): 660W
8 ohm stereo (per channel): 400W
4 ohm bridge-mono: 1950W
8 ohm bridge-mono: 1320W
Load Impedance: Safe with all types of loads. Rated for 4 and 8 ohms in Stereo mode, 4 ohms in Bridge-Mono mode
Voltage Gain to 1-kHz, 8-ohm rated output,
CE 1000:
30.5-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.34-volt sensitivity.
CE 2000:
32.1-dB gain at 1.4-volt sensitivity;
26-dB gain at 2.83-volt sensitivity.
Required AC Mains: 50/60 Hz (North American units are 60 Hz only); 100, 120 and 230-240 VAC (+/-10%) units are available.
AC Line Current,
100 Volts: 11.4 A;
120 Volts: 9.5 A;
230-240 Volts: 5.0 A;
At Idle: All amps draw no more than 90 watts.
AC Line Connector: NEMA 5-15P (15 A).
Sep 07, 2012 | Crown CE2000 2-Channel Amplifier
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
this is actually the product description for your speaker
Product Description
Front
Speaker Unit: 1inch +6.5inch *2+8inch
Power: 10-100W
Sensitivity: 88 dB
Impedance: 4 ohm
Frequency Response: 45-20K Hz
Production Size: (H*W*D) 1087*210*336mm
Package Size: (H*W*D) 1162*500*400mm
CENTRE
Speaker Unit: 1inch +4inch *2
Power: 10-60W
Sensitivity: 86 dB
Impedance: 8 ohm
Frequency Response: 75-20K Hz
Production Size: (H*W*D) 160*500*179mm
SURROUND
Power: 10-60W
Sensitivity: 85dB
Impedance: 8 ohm
Production Size: (H*W*D) 225*160*158mm
Package Size: (H*W*D) 550*273*415mm /3PCS
ACTIVE SUBWOOFER
Speaker Unit: 10inch
Impedance: 8 ohm
Crossover Point Control
Handling Power: 120W
Production Size: (H*W*D) 405*328*350mm
Package Size: (H*W*D) 465*330*465mm
Jun 24, 2010 | Juster SP-615 Computer Speakers
My 8000s has developed a hum which is audible in both speakers. When the amp is first switched on I do not hear it but after about an hours use it becomes apparent. The volume of the hum is constant and...
My first thoughts are to replace the large electrolytic capacitor(s) their will be at least two I think, as they could be getting leaky. Though they could be fully charged up on switch on (hence no noise) they could lose it as time passes and let the 50/60 Hz mains hum in (which they stop). Another cause could be a semi-conductor that has become heat sensitive. This again could be in the power supply or something that has both channels running in and out of it. This is because the noise is in both channels, so can't be something that deals with only one channel, even if there are two of them!
Replace the caps first, if that doesn't solve your problem, then get some Servisol Freezer spray and spray any suspect part (one at a time) when it acts up! If the noise goes you have the culprit.
May 20, 2010 | NAD C372 Amplifier
Dvd player wont read disk
Apr 07, 2009 | Televison & Video
My NAD cd/dvd T550 displays NO DISC.
I have the same problem. When I insert a disk, my NAD T 550 DVD player displays 'No Disc'. It started with new disks while still reading older disks, but at some time it stopped recognizing any disk. Did you receive any suggestion yet or has anyone a suggestion?
Jan 27, 2009 | NAD T550 DVD Player
NAD T532 probem
CD and DVD disks use a different set of optics for each type of operation. Some units have a different laser for the different format types.
The fault could be mechanical alignment, calibration, or a failure in the signal and or processor path. These types of faults are impossible to guess at.
If the unit is under warranty, contact the dealer to find out how to get it serviced. If out of warranty it may not be feasible to service.
Jerry G.
Dec 02, 2008 | NAD T532 DVD Player
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
LG home 5 disc dvd changer
try to clean the dvd player it could be the lens that is having a hardtime reading the disk and it causing the noise
Jul 21, 2008 | LG LXD5230 System
Televison & Video Logo
161 people viewed this question
Top Televison & Video Experts
Electro Med Services...
