Hi-Grade laptop tries to boot but fails and retries then doesnt do anything.
Windows Vista Basic, Intel Celeron M Inside. basically i press the power button, the power, battery, and charging lights turn green (accept the charging light which is orange.) i hear the fans booting up, but no images are being processed to my screen its all black. like no sort of image not a black screen just as if it was turned off. then the power light goes off for around 2-3 seconds and then it comes back on (fully lit to green, just as it did when i started it up) then repeats this process for around 3 minutes until it just stopes and the lights stay on (green,green,orange). help? :/
    Master:
  • Computers & ... Master
  • 604 Answers
Put your vista recovery disc in it and restart it
Posted on Apr 19, 2017
zzedly
  • 300 Answers
SOURCE: Dell Latitude C510/610 wont turn on
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Posted on Mar 07, 2008
mewms_14904
  • 1027 Answers
SOURCE: Fails to boot
You might try a Hirens Boot CD, un-zip the files, create a bootable cd from the .ISO file and boot your troubled system, select virus scan on boot.
Posted on Apr 16, 2008
  • 111 Answers
SOURCE: hp pavillion dv9000 won't boot. tries to start,
There is a Limited Enhancement Program that includes this model. If you are in the US call 1-800-474-6836. If you are outside US check the HP.com website and search for the Limited warranty enhancement Program.
This is normally a video chipset issue that is embedded in your MB. If your notebook is part of the program, hp will shoulder the repair cost for the MB replacement.
Please vote, Thanks!
Posted on Jun 27, 2009
ticthak
  • 43 Answers
SOURCE: My eee pc 4G surf won't turn on. It started
Most likely, either the power jack inside the machine (jack itself or solder joints) or the plug on the power cord was damaged; obviously the plug is only a few dollars to replace, the jack also only a few dollars, but much more labor intensive. My experience tells me it's probably the power jack. If you have any way to externally charge your battery and, using it, find the machine operational, that pins it down pretty well. When the external supply is used, the internal battery is supposed to be switched out of the load circuit and into charging mode.
Posted on Aug 12, 2009
  • 4090 Answers
SOURCE: Can't turn my lappy on
Damaged Bootstrap You need to take it for repair
Posted on Aug 16, 2009
EMachine W3507, will not boot after adding 2GB of memory. (2x 1GB; one in each slot). It will boot with one stick, but only if the original 512MG is in slot 1. The 512MB is not recognized.
Where they purchased as a working pair some motherboards will only accept working pairs>?
Make sure RAM modules are of same brand and type try one ram module at a time in the working slot closest the cpu if both work individually they are not a working pair
Sep 06, 2013 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Monitor have power and dont start
is this a crt monitor (bulky glass screen) or a panel type?
May 10, 2013 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
Im using compaq laptop, installed with Vista Basic. when i turn it on it loads, but after that it remains blank, I am certain that it is not LCD problem. What can I do?
If you just recently installed Windows Vista Basic and all you get is a black screen with a white cursor that is blinking, then the operating system did not install properly.
Go ahead and reinstall the operating system using a Windows Vista Basic CD and let the installation go through all the way.
If the problem persists, I would recommend finding a boot CD that has mini XP and run check disk.
If you have more than 4KB in bad sectors, then your hard drive is failing and isn't able to write the Files properly to the hard drive from the Windows Vista Basic CD.
Also, check the memory using a tool called Memtest. If you have bad memory, that would also be the reason why an installation can't be done properly.
Hope this was helpful.
Apr 13, 2011 | Intel Computers & Internet
I deleted too much stuff off my 1g emachine desktop and now it wont even start windows says its missing the boot manager. how can i fix it without a backup disk
Hi ,
Unfortunaly , you can't . You need the install disc . You can retreive existing data by extracting the hdd from your desktop and connect it to a healthy computer . Format the HDD afterwards , put it back into the desktop and launch install disc .
Jan 22, 2011 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
The windows xp and Vista no detect Network Card The computer is emachines t3656
if the network card in onboard or on pci slots then install the appropriate driver
Apr 14, 2010 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
JVC Digital Still Function 32X
I'd try using a different cable to connect to the PC. The one you are using could be faulty. It does happen sometimes.
Mar 14, 2008 | JVC Digital Video Camera
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
