Question about Konica Minolta Konica Bizhub Pro 920 Toner 022J
Konica minolta bizhub pro 920 won't scan to email
Tried rebooting. Screen just says uploading but won't send.
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
  • 566 Answers
SOURCE: How do you scan to PDF on a Konica Minolta Bizhub
Touch [Fax/Scan] to display the initial screen for fax/scan operations.
Touch [Scan Settings] to specify detailed settings for scanning
In Scan Settings >File Type , select elect the file type for saving the scan data. The following file types are available (PDF,Compact PDF, TIFF, JPEG, XPS, Compact XPS).
Touch [PDF] or [Compact PDF]
In addition, the grouping of the saved data (single PDF or multi-page PDF) and the encryption settings (encryption level, password, document permissions, and other detail settings) can be specified.
You should check the user’s manual for images and more detailed info on how to operate the machine.
You can download it from here:
http://download6.konicaminolta.eu/konmin/servlet/KonMinMaster;jsessionid=9D04D81DD26189D21B3B2B8B32D2B06F.node02?path=../search.jsp&mode=show&document=32545
Posted on Jul 22, 2009
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
  • 19 Answers
SOURCE: how to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
Posted on Jul 28, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
Sc 35 -02
Fusing unit upper roller thermistoe defective.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON.Keep pressed the Utility key when appear Trouble reset message on screen.Reset and turn OFF the copier.Wait 1 minute and turn ON.
Dec 07, 2013 | Konica Minolta Konica Bizhub Pro 920 Toner...
I have to Konica Minolta printers one a BizHub C220 & the other BizHub C353. All the scan to email function except for to users that have a large email account. I did setup an alias and forward the...
Hi Tim,
Can you please let me know the exact error message that you get , while you attempt to use the scan to email function?
May end users believe to scan-to-email to themselves internally, and then send it externally.
and the find it as a probably better option, as we get to preview the attachment before it goes out.
If you are using an exchange server then the exchange cannot handle the message size or attachment size, as well as when there is actually not enough space on the server probably it's full or near full.
Try setting up the email account again and then check if the problem persists, most probably this problem would not persist after a reset of the email account.
Hope this helps...:)
Aug 29, 2011 | Konica Minolta bizhub C250 All-In-One...
What driver do i use to scan using windows 7 for konica minolta bizhub 350 just upgraded computer and it won't scan now prints ok
I believe you must install the software from the bizhub disc and if that does work you can set it up to setup it to your email as a pdf
May 13, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta 250 Bizhub scanning Operations
You need to create a "one-touch"
This can be done in the Admin Screen without having to enter a code.
Better yet is to just yype the IP address into your browser and create them there.
The copier will need an email address in order to send them and you may need to log out and then back into the 250 as an "Admin".
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Konica Bizhub Pro 920 Toner 022J Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
