Question about HP LaserJet 2550L Printer
Frequent paper jam
When printing multiple pages, paper jam occurs
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 22, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
Printing multiple page pdf on kodak esp c310 AiO
I had exactly the same problem as you! Whenever I printed anything of more than 1 page the paper jammed. I now know why... When you go to File>Print in Adobe reader, the print window displays a load of options. Simply uncheck the 'Print on both sides of paper' box. This worked for me! Hope it works for you!
Eoghan12
Jan 31, 2012 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
Frequent Paper Jams in Brother HL-2140
Every 120,000 pages, the paper feed rollers, fuser, transfer roller, and OPC belt cartridge should be replaced, usually by a trained techncian.
Fuser and OPC belt units are customer-replacable.
The multiple feeding of the paper into the printer is due to a worn paper separation pad. part no. LM0711001. If the machine is picking up the paper okay and the jams occur solely from multiple sheet feeding, then this part is probably all you will need. The steps required to access and remove & replace the separation pad unfortunately is about 10 steps. Better consult a tech.
Oct 06, 2009 | Brother MFC-9420CN All-In-One Laser...
Paper jams on Canon MF3240
Start with the paper itself. Make sure it is in the machine properly. Here is a short guide on a few things to check:
http://cincinnatiprinterrepair.com/paper-jams
Jun 17, 2009 | Canon imageCLASS MF3240 All-In-One Laser...
Copier Only prints half the page
Sounds to me that the paper tray is set incorrectly. There is a dial on the back of the machine that needs to be set correctly once the paper tray guides are adjusted accordingly -particularly when running 8 1/2 x 11" (letter) size paper. It can be set to run either lengthwise, or laterally (portrait) make sure the dial is set to the proper setting on ALL trays. If the tray is set for lateral, for example, and the paper is installed lengthwise, the scanner only utilizes 8 1/2" in length rather than the full 11". Frequent jamming is also a common problem when making multiple copies, because the paper is not where the machine "expects" it to be. Also check that the LCD display reads the proper size / orientation after adjustment.
Hope this helps. Please rate solution :)
May 21, 2009 | Gestetner Copier
HP 4700n Paper Late Jam
duplex area related jam in other printers. is problem only occurring in tray 1. If so, there is a problem with the tray. If it's happening from tray 1 and tray 2, replace try replacing transfer belt.
May 27, 2008 | Office Equipment & Supplies
HP LaserJet 2550L Printer Logo
142 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
