Question about GE 169220 53 Toaster Oven 17in x 14in x 12in Metal Plastic
Calibrate temperature on toaster oven
Oven does not heat to full temperature does it have to be returned to calibrate or can it be done
4 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: 169068 GE Toaster Oven - no heat
remove the plastic side where the controls are . if you see a broken wire you might be able to repair it otherwise theres no parts made for it ,so no matter how simple the broken part is .....there is nothing that can be done about it ........ WELCOME TO THE WORLD OF "MADE IN CHINA"
Posted on Feb 05, 2009
cactus bob
  • 267 Answers
SOURCE: I have a new GE Covection Toaster Oven model
YES this is normal it is how it regulates temp by cycleing the elements ......................Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 03, 2009
  • 7 Answers
SOURCE: WE HAVE A GE 169104 TOASTER OVEN
Do you still need top elements or do you still have your GE 169104 oven?
Posted on Jan 04, 2011
Frigidaire Professional toaster oven is displaying E02 error what do I do ?
Oven temperature too hot. Check and replace oven temperature sensor (RTD)
Sep 27, 2014 | Frigidaire Professional Convection Toaster...
What part needs to be replaced when the lcd and controls work but no heat?
Most likely suspects in this scenario would be the heating element or the temperature sensing rod. Not sure what the sensing rod setup on this oven looks like, but it is generally a few inches long, similar diameter to a charging cable for your phone, attached to the back wall of the oven and sticking out directly toward the oven door. If it goes bad, the oven may think it has reached the set temperature and turn off, but generally, it is the opposite (it allows the oven to get too hot). My guess is heating element, but the sensor generally costs a lot less to replace, though maybe not with a small toaster oven. Good luck!
Jul 18, 2014 | Breville BOV800XL 1800 Watts Toaster Oven...
I have an Applica / Black and Decker Toaster oven, model CT0650. Can I still buy a temperature control for it?
http://www.directpartsandproducts.com/black-decker-parts-accessories-c-1.html?osCsid=1kicup2s295ac117g8sv0mcuf7
That is an address for a place that carries parts for Black and Decker or their phone number is 1-800-738-0245.
If that doesn't work then try this web address that will return a list of sites that sell oven parts.
netshoppers.com/search/index.php?phrase=oven+parts&uid=d5d00793c96dccbcaa9b5f3ca3d412cd&kuid=4c4a6ef184c15b7eeffee322a7d94921&src=7s
Mar 12, 2011 | Applica FC150R Toaster Oven with...
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Oven has No Temperature Control
    Yes they are servicable and you can do it yourself easily if you're handy. Go to smallappliance.com for parts, or just search "small appliance parts" and you will find a few places that have B&D parts. I'm pretty sure the thermostat switch is available for your oven. You will need the model # from the oven.
    Jan 24, 2010 | Black & Decker Textured TRO700 Toaster...
    Oven does not cook at temperature set at. 2 hrs.
    Could be the gasket is not sealing in the heat and you are experience heat loss through the door. Does it seal tightly? Can you feel heat coming around the door area? If so, replace the gasket
    Nov 05, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
    Sunbeam toaster oven upper heating coil not working
    the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
    Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
    Krups fbc2 toaster oven cuts off while toasting
    returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
    Sep 27, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
    What is exactly a toaster oven?
    A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
    Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
    GE 169220 53 Toaster Oven 17in x 14in x 12in Metal Plastic Logo
    56 people viewed this question
    Top GE Toaster Ovens Experts
    Mack Baxter
    Tom Chichester
    Bill Boyd
    Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
