"Can't find second dimm slot on ASUS K84L" - Computers & Internet
3 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Posted on Mar 29, 2009
marketex
  • 371 Answers
SOURCE: Installed 1G RAM in DIMM 2 slot(correctly!). Not recognized
Do the two sticks match, all the way down to VENDOR?
Posted on Apr 10, 2009
ASUS Motherboard M4A88T-V EVO/USB3 won't post
Specs say it is a dual channel platform for the memory slots. It requires two DIMMs to take advantage of this, but you would have double check the manual if it will run with a single DIMM.
Feb 04, 2013 | ASUS Computers & Internet
What is the max memory on asus k84l-7kvx
Hello you can find info about your pc here:
http://www.asus.com/
By selecting the model.
But i think the limit is, 8 gb of ram, 2x4 gb.
Good luck
Jan 14, 2013 | ASUS K84L-7KVX 14" Laptop Intel i3-2350m...
Why cant i get my 4x 2gb ddr2 800 to work on my asus p5qc mobo? it will run fine with just 4gb 2x ddr2 800 but when i add the other 2x ram i get black screen at boot
Be sure to check which slots you are putting them in, stay within the same colors as to which needs to be put in.
This may be why, looks like your using DDR2
DDR2 1066MHz DIMMs work only on the black slots for one DIMM per channel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACK slots!
This may be the case for all speeds of DDR2
http://www.asus.com/Motherboards/Intel_Socket_775/P5QC/
Jul 16, 2011 | ASUS P5QC Motherboard - Intel P45, Socket...
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
My second dimm of motherboard don't work
Verify both DIMMs are the same size, speed and type. Most motherboard aren't capable of juggling different speed or size memory banks.
Try swapping the two DIMMs or reinstalling the nonfunctional DIMM in slot 0, alone, instead of in slot 1. If it does not work this way, it's probably busted or incompatible.
If it works, place the original first DIMM in slot 1. If it doesn't work, the two DIMMs are not compatible after all (or the slot itself is busted or there's some dirt in it preventing a good contact; it happens. Blow some compressed air from an air can to clear it).
Nov 02, 2009 | ASUS P5VDC-MX Motherboard
Mar 29, 2009 | Computers & Internet
Does GA-8I945P motherboard support high density memory?
You have 4 slots available. Each slot can take a 1gb non ecc memory module with the specs below.
4 DDR II DIMM memory slots (supports up to 4GB memory)
Supports 1.8V DDR II DIMM
Supports dual channel DDR II 667/533/400 DIMM
Mar 22, 2009 | ASUS P4VP-MX Motherboard
Qvc said my ram isnt on the list
From the Asus website - "DDR2 1066MHz DIMMs work only on the black slots for one DIMM perchannel. Ensure to install the DDR2 1066MHz DIMMs ONLY on the BLACKslots!"
Your motherboard only has two black slots. You can install larger capacity sticks of RAM in those slots, but you can only use two. Most likely you are getting the incorrect reading because you have four installed.
Jan 26, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Burnt DDR DIMM socket
It may be possible, but the system may very well become unstable at times. The purpose of the different color dimms is either daul band memory and or hypertheading, which means the memory needs to be matched and in pairs to work correctly. I would try one pair in the same colored slots in which one of them is not burnt. Also can you get it to boot with one stick of ram in a slot? Have you seen this board boot at all with 1 burnt slot (Known Good Board). Hope this was informative to you. Good Luck, Let me know how it works out.
Jun 09, 2008 | ASUS P4P800-X Pentium Motherboard
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
