2 black spots about 0.6cm in diameter in top left hand corner of screen. It doesn't affect the pictures but does obscure the menu
SOURCE: Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
SOURCE: I can turn my camera
When the camera is set to C-AF (Continuous Auto Focus) mode the focus is continually aligned according to movement of subject or the camera even when shutter button is not pressed. The Continuous Auto Focus (C-AF) is disabled while the camera is zooming in and out. Once the camera stops zooming the CAF is initiated and the cameras focus is adjusted.
This is actually used for video.
SOURCE: Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
SOURCE: I have black spots on
Yes i have a solution,i would like a replacement. This camera is still under factory warranty,and i cannot see how those black spots can be fixed,because they appear on the inside. Please tell me how i may replace or return. Thank you.
SOURCE: camera wont turn on
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
