Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
How do I repartition a WD 500GB MyBook Firewire with data on it?
  • 36 Answers
Greetings.
If you have data already, you will need to buy third party software to do the job. i recommend norton partition magic , easy to use and works. Before you purchase you have to clarify to if firewire will be detected after reboot.
Hope that help.
Posted on Jan 10, 2009
Dropped the TB from about 2 feet onto the carpet...it lights up, does not open but requires me to remove hardware, it has everything I have ever done in the Army on it, plus pics....I have a 500GB drive as...
Let's try to recover the data because the cost for disaster recovery is unreasonably high, approaching a thousand dollars.
Do not take the drive to any national computer supply stores/chains. The geeks will format the drive, if they get a chance to do so (and tell you to restore from backup).
These steps will not further risk losing your data.
You may also need to request "FixYa Premium Support".
Please keep in touch via comments or a new post and refer to "Gort007" if you need to contact me.
Read Options A and B completely before deciding which to do.
A. This requires opening up the unit.
1. Unplug all cables from the drive.
2. Open the WD World book
3. Re-seat the data and power connectors.
4. Check the connections again. Re-seat the data and power conenctions, again.
5. Carefully re-assemble.
6. It should work, if not do the steps in "B."
B. This does not require opening up the unit:
1. Purchase Avanquest Partition Commander ($50). Other experts may suggest a different or free utility. I trust Partition Commander.
2. Purchase a 500GB (or enough to copy your data) hard drive or another WD My Book, or any other external USB (or eSATA if your computer supports it).
3. Connect the NEW disk and delete all of the partitions. This is the NEW disk or external drive.
Do not create any partitions on it. The "Partition Commander" will do it.
4. Connect the damaged WD Mybook to the computer and boot the computer with the Commander CD.
5. A list of the disks will appear after selecting the default menu selections.
6. If the Mybook does not appear, then this option will not work until the steps in the "A." section above.
7. Copy the Mybook partition to the new hard drive.
8. If unable to do so, then try to browse the Mybook and copy folders to the new hard drive.
9. At this point yu may have to create a new partition on the NEW drive in order to copy your data to it.
10. If this does not work for you, please either do the seteps in "A." above, or explore Partition Commander more.
11. Partition Commander will triple check with you to be sure you do not do any steps that you didn't mean to.
12. Do not format your damaged drive, even after you recover the data. It is your ultimate backup.
-Gort007.
Oct 08, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Western Digital MyBook suddenly no more responding. It worked perfectly over years, but one morning I entered the office, and the blue rings were on. But iTunes didn't play any songs, the library is...
You may be able to remove the hard drive manually and try another USB adapter to access it on your computer.
Might be pootched though.
Rule of thumb is to never save your files to only 1 source. Its not a question of if a hard drive is going to fail but WHEN.
Sep 26, 2009 | Western Digital 500GB MyBook Office...
Computer doesn't recognize WD MyBook 500GB but no error message
Try using the western digital knowledge base info to help you resolve the problem...click here.
Otherwise, we need the full model # and the OS you're using to give better solutions....
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
Can I Repartition WD 500GB My Book Firewire Drive w/DATA ON IT?
Greetings.
You will need to have a third party software to achieve this. I recommend norton partition magic. I have been using it in the same scenario as yours and works. they now support firewire. Easy to use and gets the job done.
Hope that helps.
Jan 10, 2009 | Western Digital My Book Essential Edition...
WDC WD1600 netcenter with 1 TB external WD MyBOOK
just called western digital and the solution is: buy an 500Gb disk, that is the max this machine can take....
Nov 21, 2008 | Western Digital Essential NetCenter...
I recently purchased a Dell XPS 420 Desktop computer, running Vista, from Dell, including a WD 500GB MyBook external hard drive. The power button did not function from the get-go, but I was able to copy...
Unfortunately if there is no driver for Vista, then your out of luck. Since Vista is a widely used OS and getting bigger, then the MyBook manufactures must create a Vista driver soon or they will be in danger of going out of business. Just wait and periodically check the MyBook website for new drivers.
Feb 11, 2008 | Computers & Internet
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
MyBook 500GB Home Ed hangs WinXP SP2 boot up process
Thanks to Guest above. I was having the issue with USB of my WD drives causing the system to hang upon boot up. Disabling USB Legacy did the trick. It's only my WD externals that were causing me the issue but no mor
Jan 24, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
