Question about RCA RTD317W Theater System
Connect cable box with home theater system and flat panel tv
5 Suggested Answers
SOURCE: RCA LCD Flat Panel HDTV and RCA Home Theater System--No sound
Video comes from external device to TV - OUT on device and IN on TV.
Sound connects by the red/white cable set (or HDMI). Place set in Audio OUT ports on TV and Audio IN ports on DVD. Then select AUX IN on DVD.
Posted on Apr 05, 2010
  • 334 Answers
SOURCE: i have rca home theater system rtd215 plays dvds
This reson you are not hearing any "TV AUDIO" through your RCA surround system would be due to your tv sound output not being connected to an audio input into your surround system. You can hear DVDs,CDs and radio possibly mp3 if connected, as these are built in to the amplifier which the speakers connect to.
If the tv has a Line out (via phono plugs) and NOT via headphone out, connect it to an audio input on the RCA surround system. If the RCA has no other available inputs, well....there ain't a lot you can do but watch CSI with the sound from the TV and then Star Wars (for example) through the TV and Surround system.
Best Of Luck
Posted on Sep 03, 2010
Testimonial: "thank you very much"
dunnbiker
  • 8546 Answers
SOURCE: I am having trouble hooking
The manual...
http://www.1800customersupport.com/productdocuments/RT2906_RCA.pdf
Posted on Feb 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: I am trying to hook
The TV has nothing to do with listening to the radio. All the TV REQUIRES in as a minimum is a video input from the RTD. Page 2.
http://www.retrevo.com/support/RCA-RTD217-Home-Theater-Systems-manual/id/2869dj192/t/2/
Your other devices may have guidance in their manuals.
Posted on Aug 12, 2011
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
How do you attach an x-box to the yamaha natural sound home theater system dvr s200??
You need to use an optical cable to connect your xbox to your home theater system.
This can be done 2 ways
1) You can connect the optical cable directly from the xbox to the home theater system.
2) You can also connect your xbox to your TV by HDMI and then connect your TV by optical cable to your home theater system.
This has the added benefit of all the devices that use your TV being able to use the home theater system in the same way the xbox is using it.
Regards,
sjstore2
Dec 18, 2010 | Yamaha DVX-S200 System
LOST MANUAL HOW O YOU HOOK UP THE SURROUND SOUND TO TV
1. Does your TV has an Audio OUT? If it does then connect the TV audio out to your Home Theater system's Audio In.
2. Are you using Cable box? If you do then connect the Audio out of your Cable box to the Audio In of your Home Theater system. video out of your cable box to the video in of your TV.
Jun 25, 2010 | Philips Magnavox MRD500VR System
Connecting new LED TV and home theater to multiple components
the easiest way to get signal to your HT-Z320 is to run the audio cables from your cable or sat box to the input on your theater system...for the dvd either run HDMI to the LED TV or component (whatever it supports) the Wii system can be plugged into any AV -IN on the LED tv (if you want to use the Wii on the theater system you will need to extend your RED AND WHITE audio signal cables to the input on your theater system.
Hope this helps.
Feb 27, 2010 | Samsung UN55B6000 54.6 in. LCD HDTV
I want to connect the Audio from tv to Surrounding audio system
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
Can't hear TV throug home theater
all wrong! look at the back of your tv input panel you will see 2 rca jacks labelled audio out use rca cable (stereo) then connect to your audio receiver input labelled tv or any available input like cd vcr ....etc.let me know.
Dec 09, 2008 | Panasonic Home Theater System System
Connecting a Protron PLTV 3250 to a home theater system
Standard RCA cables are fine to connect both units. If home theater and tv has Component Video (Green-Red-Blue) connections, you can get better video result.
Sep 11, 2008 | Protron PLTV-32 Television
Panasonic 1080p Plasma TH-42PZ80U Home Theater Setup Question
Hey Gamer1827,
While I personally can't provide you with any model-specific home theater system recommendations, there are a couple of common ways that you can generally configure your home theater.
Connecting several devices directly to the HTIB system may typically allow you to minimize the number of remote controls necessary, as long as the HTIB system supports the use of a universal remote. Should you not necessarily care if you have to change back-and-forth between two remotes however, you may have a wider variety of possible configurations available.
In order to use only HDMI cable connections to set up your home theater, you most likely would need an HTIB system with three HDMI ports: one for your TV, one for your PS3 and one for your cable box. Each device would require a separate HDMI cable running between it and the receiver. This option (in theory) would allow you to use one universal remote to control each device, assuming that they are all compatible with the same remote.
Another common configuration you might wish to try requires you to connect your cable box and PS3 directly to your TV. By doing so however, you might limit yourself to using an optical digital audio cable to make the connection between your TV and many HTIB systems. In this configuration, the cable box and PS3 would again have their own separate HDMI cables, while the optical digital audio cable would need to be run from the Digital Audio-Out port on the back of your TV to the Digital Audio-In port on the receiver. This option essentially treats the HTIB system as an expansion device, instead of the center of your home theater configuration.
Should you need any additional information or suggestions, remember that you may always speak with a sales representative at your local Best Buy™ store for further assistance.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 12, 2008 | Televison & Video
RCA RTD317W Theater System Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
