Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer has power but will not come on display lights come on and o
I checked fuses with ohm meter they are good....the dryer has power to it. the light inside comes on but the panel lights light up in sequence then shut off then light up again....the panel makes beeping sounds when you push the buttons but no responce....i also checked the heating element and it's good.....
    Sergeant:
  • 311 Answers
How about door switch.it must close to start dryer
Posted on Jan 10, 2009
My Whirlpool Electric Dryer GEW9250PWO .
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Feb 22, 2015 | Whirlpool Dryers
My whirlpool duet dryer periodically has no signs of power. No lights, no digital lit numbers, no nothing. After a few hours it suddenly starts working. Any ideas?
Intermitent problems are the greatest challenge. I would check for a fuse usually located inside the back large back cover of the dryer. A fuse can be checked with a multi-meter with the ohm meter and when one touches the probes to both sides of a fuse, the ohm meter should go to zero. A fuse that has failed will not go to zero. The fact that the problem is intermitent leads me to believe that the fuse may be about to fail or that a wire to one side of the fuse may have come loose. Remember that a dryer does vibrate and wires can come loose in time. Be sure to unplug the dryer before checking the fuse. Whirlpool and Kenmore are I believe made by Whirlpool. Check Searspartsdirect.com for the needed fuse. Have the Model # and serial number handy to facilitate the process. Good Luck
Aug 05, 2014 | Dryers
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
Tail lights dont work everything else does
if you have a volt meter, turn on the lights and either take out a bulb or
unplug the harness going to one of your rear lights. the using the meter (switched to VDC) see if you power going to the lights if not, you have a wiring harness or a fuse issue. If you have power coming back to the light, switch you meter to Ohms and check to see if you have continuity on the bulb itself. you can also check your fuse with the meter on the Ohm setting.
Dec 16, 2012 | Cars & Trucks
Will not run no lights or anything
The most probable thing wrong is going to be a blown fuse on the control panel. To check for that, disconnect power to dishwasher by turning off circuit breaker ,remove torx headed screws from around the inner door,seperate inner/outer door panel,remove the plastic cover off of the control panel, and use a multimeter set to measure ohms and remove the 2 wires to the thermal fuse and check for continuty with ZERO ohms resistiance on the thermal fuse. IF the fuse is blown the meter display will show OL or the display will not change...if using a meter with a needle the needle will not move if the fuse is blown..if the fuse is good the display will show 0.00-1.00 on a digital meter and the needle will swing all the way to the right and stay there on analog meter. If the fuse does check to be good the most likely cause of the diswasher not running will be the door switches. Here is what the fuse looks likeoldtech2332_88.jpg
Good luck i hope i helped you to fix your dishwahser,
GENE
Sep 04, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our dryer wont start is there a reset button
Their is no reset button but what most likely caused that is a blown thermal fuse. the thermal fuse is located in the rear of the dryer behind the back panel,in the housing where lint filter fits into. The thermal fuse is white in color and oval shaped with 2 blue wires to it. IF bad it must be replaced since it is not resettable. To check it DISCONNECT POWER TO DRYER remove wires to it and use a ohm meter set to a low setting and check it for Zero ohms,if the display on the meter shows OL it is bad.
Gene
Aug 05, 2011 | Estate TEDX640JQ Electric Dryer
Hello I have a MAYTAG NEPTUNE DRYER Model# MD5500 (MDE5500AYQ) . The console panel lights up.You can load up a cycle on the display but the unit won't start. It Just beeps or locks up.So I checked the...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 30, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore electric dryer model number 86860100 dryer not heating.....cleaned out vents not the problem....everything else seems to work.. I had seen in the past it glow in back of the dryer so I turned out...
hello there:
Testing with an ohm meter checking on a dryer....
These are the places that pass voltage to the heater elements on an electric dryer. In order to check a dryer for no heat, here is a list of places to check. Remember to always unplug the appliance before starting testing with an ohm meter. Always remove wires from the part you are testing with an ohm meter ( write down what goes where first before removing any wires ).
Meter testing and usage tips.
1. Power supply-check power supply at terminal block where cord enters the dryer. Should read 240V. If you read 240V here, tested with a volt meter, unplug dryer and test components with ohm meter.
2. Thermostats-Cycle and safety thermostats-read them with an ohm meter. Should show continuity . How common thermostats work.
3.Timer-The timer has a set of contacts that pass voltage to the heaters. If you can not determine by wiring picture what they are, check across the two terminals with the largest wires on them. The heater wires are almost twice as large as the others. You should read continuity with timer in heat mode.
4. Thermal fuses-In recent years the makers of dryers are using thermal fuses to let you know something is wrong with your dryer. They are generally non resetting and have to be replaced. The thermal fuses are located on the heater element housing and should read continuity if read with an ohm meter. Most blown thermal fuses are the result of vent/air flow problems or a grounded heating element.
5. Selector Switches-Read the wiring picture and determine which switch is closed. You should read continuity across closed switches.
6. Safety Switch on Motor-There is a safety switch on motor to insure that heaters can not come on unless motor is running. It is normally open when the motor is idle/not running, and closes when motor runs. In order to check with an ohm meter, remove the two large wires on motor switch and make them electrically safe. Tape them. Plug the dryer in and start motor. Check continuity across the terminals on the motor switch you removed the heavy wires from. If it is ok you should read continuity. Remember that the smaller wires in a dryer carry the 120V and the large wires carry 240V. There is no voltage on these two terminals with wires removed. It is ok to test with ohm meter.
7. Heat elements-Test heater element with an ohm meter. You will read continuity across a good element 8-12 OHMS
Jan 09, 2010 | Kenmore Dryers
Model # PYE4500AYV Serial # 11168132AV. The dryer just quit
are getting power to section switch, any internal fuses. also check the safety switch on the door.
Jun 24, 2009 | Dryers
Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Jan 19, 2009 | Kenmore Dryers
Maytag Neptune MDE5500AY Electric Dryer Logo
250 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
