Question about Maytag Centennial MTW5800TW Top Load Washer
Sensing lights flashing on maytag centennial washer wont start, can you bypass
beltronic205
  • 1466 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
richroth
  • 9472 Answers
SOURCE: I have a Commercial Series
Replace the "water inlet valve" on your machine. If you could post your model number I can point you to the part you need.
Posted on Dec 26, 2010
richroth
  • 9472 Answers
SOURCE: Washer immediately goes into wash cycle when
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Jan 26, 2011
appliancguy
  • 86 Answers
SOURCE: Maytag centennial washer - power went out while
Set the timer to any off position. Unplug the unit for 10 minutes. Plug it back in and try that. The worst thing
you can do to a Maytag washer is advance the timer yourself...hope this helps.
Posted on Apr 02, 2011
  • 3287 Answers
SOURCE: I just purchased a Maytag centennial washer. I
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Posted on Apr 20, 2011
Testimonial: "Thank you so much. I looked on pge 8 you are right. Wonderful site. More people should know about this. Thank you more than I can say. "
Lid Sensing light flashing on maytag centennial washer wont start
could be the sensor has gone bad..but try unplugging for little while then reconnect it..it may reset ..good luck...also try Maytag help and support online..customer services
May 23, 2016 | Maytag Washing Machines
Sensor light not coming on after fill cycle
After fill it should be washing and not sensing. What is your concern or trouble you are having
Mar 12, 2016 | Maytag Centennial Top Load Washer
My maytag centennial commercial technology washer the sensing light keeps blinking and the lid want lock what do I do.
Wipe around the inner edges of top and ledge where door meets with machine to close. removing any particles of debris. then using a pipe cleaner carefully swipe out the opening where the locking unit is on door and machine latch. again ,removing debris
Jan 24, 2016 | Maytag Washing Machines
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
Sensing light flashes buy doesnt start
You will need to replace the actuator on the bottom of the machine. Here is the part to order.
Nov 20, 2012 | Maytag Centennial MTW5800TW Top Load...
Washer won't start and lid won't lock . it keeps clicking and the sensing light keeps flashing
Thank you janesstone ive been looking for 2 hours trying to figure out that simple wire bypass i just couldnt find what wires did what. Your my hero for the day lol. Everyone should be able to find this answer easier just sayin
Oct 26, 2012 | Maytag Centennial Series MVWC200XW
Want to disengage lid lock on maytag centennial
I had the same problem. The lid lock assembly is broken. If you are under warranty get it replaced. If not remove the top of the washer and take out the switch assembly. The 4 wires going in are Yellow, Red, White, and Blue. If you short the white and blue together, the washer thinks the lid is closed. If you short the red white and blue together the washer thinks the lid is closed and locked. The yellow is only there to activate the electromagnetic switch.
Disconnecting the switch assembly will not work.
The electromagnet locks the lid and it also unlocks the lid. It is not a matter of cutting the power to the magnet.
Installing 2 switches that connect the red white and blue is the best option if you want to remove the lock.
The first switch should connect the white and blue. (LID CLOSED)
The second should connect the red to the white/blue connection. (LID LOCKED)
After that the lid should work.
Please post a follow-up if this works for you.
GOOD LUCK
Jul 09, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag Centennial MTW5800TW Top Load Washer Logo
249 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
