Question about Kenmore 72802 Gas Dryer
Dryer not spinning
Our kenmore gas dryer would run all of the time...even when the door was opened. Now it stopped working. It makes a little noise but the tub doesn't spin at all now.
  • 640 Answers
It makes a humming noise..defective motor,,also you need to replace door switch...onthejob
Posted on Jan 12, 2009
Frig. gas dryer agq6000es not tumbling
Do you hear the motor running? With door closed.
Most dryers will spin though a little hard to do so. If it spins VERY easy the belt is possibly broken.
If the dryer is several years old it Could be the belt.
Also check for a switch for the door, if there is one.
Door switch would shut off dryer when opened.
Nov 29, 2013 | Frigidaire AGQ6000ES Gas Dryer
Duet dryer is making a humming noise when cycle starts a d during
whenever i hear a humming sound in a dryer it's usually the motor or something caught in the blower wheel stopping the motor from spinning.open the door and see if you can spin the drum.if it spins by hand try this,open the door,push in the door switch with one hand,have someone push the start button while you hold in the door switch and spin the drum by hand helping it move,if it runs you have a bad motor,if it doesn't remove the bottom panel and see if the belt is broke and stuck in the motor but like i say usually it has something to do with the motor not spinning.hope this helps
Oct 21, 2013 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Makes a squeaking noise when it spins
it's either a roller or the belt pulley,there's a belt kit you can buy that has a belt rollers and pulley,it's cheaper to buy it like that and has everything you'll need,next time send the model number,it will start with 110. or 417. and eight numbers after the dot,it's located around the door opening where you put the clothes into the dryer,NOT ON THE DOOR
Aug 29, 2010 | Kenmore 73952 Gas Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Kenmore 80 Series Gas Dryer won't run unless empty
MORE THAN LIKELY YOUR TENSION PULLEY IS SHOT WAS IT MAKING ANY SQUEEKING NOISES
Aug 26, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series dryer makes noise and does not want to turn. I can make it spin by hand holding the door switch in, grab it and spin it, and get it to spin again. It keeps doing the same thing when
Your motor is worn out. Bearings worn and not enough power to start it. Motor is not repairable it must be replaced or new dryer. Sorry
May 20, 2009 | Kenmore Dryers
Kenmore 72802 Gas Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
