Question about Microsoft Xbox 360 Controller
Xbox 360 Controllers went out
My son woke this morning to a dead controller.
The lights keep spinning around, the game turns on, but the controller is not responding.
What did he do?
    New Friend:
U have to connect the controller to the Xbox by pressing the button on ur Xbox that adds controllers to it
Posted on Jan 02, 2013
  • 15,935 Answers
If the batteries died, the console lost its link to the controller. It must be re-sync'ed.
Please visit this link
http://www.xbox.com/en-AU/support/xbox360/accessories/wirelesscontroller.htm
It explains how to enable/disable wireless controllers.
Hope this helps!
Posted on Jan 10, 2009
How can I get the player remotes to connect to the xbox360?
First you hold the big X button in the middle to turn the controller on. Next, after making sure your 360 is turned on, push the connect button on the 360 controller so the lights around the big X are spinning around. Finally, push the connect button on the 360( which is located directly to the right of memory unit B) and the lights around the on/off button of the console should spin. Eventually, your console will find the controller, and you will know its connected because one single light on the controller will remain lit while the others wont.
Sep 10, 2012 | Microsoft Video Game Consoles & Games
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
All 4 lights keep on blinking on my controller
You may need to "Sync" the controller to your Xbox console.
1) Press the sync button on your Xbox 360. The green lights on the Xbox will swirl.
2) Press the small white button on the controller (between the bumper buttons).
After a few seconds, the position 1 green LED should light up on the controller.
Apr 05, 2011 | Microsoft Xbox 360 Controller
The lights keep blinking but nothing is happening. It wont connect to the console. What should I do?
It's possible the xbox 360 controller isn't connected to the xbox 360. Turn the xbox 360 on by pressing the power button, and wait until it reaches the dash board. Then press the controller syncing button on the xbox 360 itself and wait until the xbox 360's ring lights start to spin around. Then press and hold the synch button on the controller (located near the charge port) and the controller should synch up with the xbox 360.
Mar 28, 2011 | Microsoft Xbox 360 Controller
Xbox wirless receiver not working!!!
Probably defective. Get you a new one.
Jul 26, 2009 | Microsoft Xbox 360 Controller
My sons new wireless controller worked 4a few days, now the light in the middle just keeps going round and it wont work.
The controller may have lost the signal from the xbox 360. You can try turning the unit on and then the controller. There should be a small white button on the front of the controller, if you press that it will search for the signal from the xbox 360. Hopefully this helps.
Jun 29, 2009 | Microsoft Xbox 360 Controller
We have 2 xbox 360 controllers. The one works fine and we use it all the time. We recently got our first 2-player game. We went to turn on the second controller but it won't turn on. It has brand new...
you have to first sync it with your xbox... there should a little white button on top of your controller, and a white button next to the memory card slots of your xbox.. hold both for 3 seconds to sync them
Jan 04, 2009 | Microsoft Xbox 360 Controller
Controllers will not connects at all.
I have the issue mostly when the batteries are about to die, Try changing the batteries, or if you are using a play and charge kit (sold seprately) connect it to your xbox 360 and one of the front usb ports. Or replace the rechargeable battery.
PAeasop
Apr 20, 2008 | Microsoft Xbox 360 Console
Xbox controller
Try re-syncing the second (non-working) controller to the console. To do this turn both the controller and the 360 on, then find the little sync button on the 360 controller and hold it down until the lights flash in a clockwise circle. Now find the sync button on the 360 console and hold it down until the lights on the console spin in a clockwise fashion. Wait a couple seconds until the two sync up and then voila, you're good to go!
Here's pics of what the sync buttons look like:
Dec 27, 2007 | Microsoft MS Xbox 360 Common Controller...
Xbox 360 wireless controller
change your controllers m8 sounds like they faulty i have had no probs
Oct 24, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Controller Logo
110 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
