Question about Maytag MBB2256GES Bottom Freezer Refrigerator
Frozen evap coil
Where is the defrost timer motor located on a maytag bottom freezer - model mbb2256ges.
thanks for your help
  • 23 Answers
In the upper food section in the middle of the light/temp control panel.
Posted on Jul 28, 2010
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Kenmore Trio Elite Refrigerator (Model 596.76583601) Won't Cool, Freezer is Fine
the coil needs to be defrosted or the defrost timer is bad also go to sears.com and you can download a manual :) hope i helped a bit
Sep 01, 2012 | Kenmore 22 cu. ft. TRIO French Door Bottom...
Maytag fridge has not been staying as cold as should. In last day freezer is starting to leak water and food not staying frozen. Have turned up controls to coldest.
I would guess that the evap. coil in the freezer section is ice up, could be a bad defrost timer or just a heavy accumalation of ice, turn it off and let it thaw, or locate the defrost timer and advance it to a defrost, the timer is usally in front just behind the bottom vent cover.
Jun 26, 2011 | Refrigerators
Meat on top two shelves unthawed while bottom two shelves is frozen and has stayed frozen for three days. Air does not appear that cold coming out of top of freezer.
hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater. now if there is frost only on the bottom or top of evap coils u may have sealed sys problem if u got an ? feel free to write me..
Apr 19, 2011 | Kenmore Freezers
How do I replace a defrost thermostat on a Maytag MBB2256GES?
Good day,
You have to remove the rear panel in the freezer compartment. The thermostat is clipped to the top of the cooling coil. Fairly simple job.
Here is a picture of one style..
May 20, 2010 | Maytag MBB2256GES Bottom Freezer...
Refrigerator keeps running
Good day,
Timer is O.K. It's doing what it should be doing. Likely the defrost thermostat mounted on the top of the cooling coil has failed. I't's a round 1" disk clipped to the top of the coil, with 2 wires coming out of it.
Remove rear panel in freezer panel to access the tstat. Could be the main calrod heater as well, but it rarely fails.
Mar 11, 2010 | Maytag MBB2256GES Bottom Freezer...
How do u access the defrost heater of the maytag mbb2256ges bottom freezer? from the rear of the fridge or remove the inner freezer panel?
Good day,
You access it from the front removing the rear panel in the freezer compartment.
Note: the heater may have failed, but has a very low failure rate.
If the machine is not defrosting, the timer and defrost thermostat ( sometimes called a limiter) are just as if not more often the problem.
Nov 04, 2009 | Maytag MBB2256GES Bottom Freezer...
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Mar 19, 2009 | Maytag MBB2256GES Bottom Freezer...
Refrig & freezer not cold enough; ice forming; low air volume
If ice/frost is building up on the back wall of the freezer then you have a defrost system failure.
Defrost system; Evap Fan, Heater, Thermo disk, Timer.
Evap Fan - this should be running all the time except when it goes into defrost mode.
Defrost Timer - This part is hard to locate on some models, a call to a parts place with the model number can help you find it and tell you if this is the type you can mannualy turn to put in the defrost mode. If you can do this, take the back panel off in the freezer so you can see the cooling coils. The heater should be red hot and melting the ice. If so, replace the timer. If not, you need an OHM meter to check the heater and therma disk.
Un plug the Ref, locate the heater, usually looks like a heating element in an oven and runs across the bottom of the coils. Touch the meter leads to each end of the heater. If no reading, replace.
Therma Disk - located close to where the coils enter the freezer, small round disk clipped to the coils. Check the same as the heater but, you won't get a good reading unless the temp is below freezing. Any doubt, just replace, it's not that expensive.
This is a lot to do, hope this helps.
Jan 23, 2009 | Refrigerators
Open Questions:
See all Maytag MBB2256GES Bottom Freezer Refrigerator Questions
Maytag MBB2256GES Bottom Freezer Refrigerator Logo
285 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
