Question about SanDisk Sansa m240 MP3 Player
Certain songs on my Sansa m240, will not play
  • beverlydawn May 11, 2010
    Are the songs protected? Pull the player up on Windows Media Player, right click on the song, select properties, select Media Usage Rights. It should tell you if the song is protected. If it is not protected, I don't know what the problem is. Hope this helps.
    Scholar:
  • 51 Answers
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade.certain songs on my Sansa - id1107_41_upgrade.gif"http://i.fixya.net/uploads/images/id1107_41_upgrade.gif" alt="id1107_41_upgrade.gif" class="h_mi" />
2. Click OK to contcertain songs on my Sansa - id1107_42_ok2proceed.gif.
 to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the folcertain songs on my Sansa - id1107_m24.gif will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sanscertain songs on my Sansa - id1107_m25_select-fw.gifp;Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.&certain songs on my Sansa - id1107_m28_finish.gifpan>
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Posted on Jan 27, 2009
  • 83 Answers
SOURCE: Synching songs to Sansa m240
YOU MIGHT NOT HAVE SYNCED RIGHT....YOU MIGHT NEED TO DRAG AND DROP YOUR FILES OR CONSIDER GETTING A SANDISK E200 OR A CX00 VERSION MP3 THEY ARE MUCH EASIER TO WORK WITH
Posted on Feb 21, 2008
bestdarngood
  • 3037 Answers
SOURCE: i need the installation disk for sansa m240
The player has 2 modes. MTP and MSC or something like that. Check the menus on the device and set it to the other one.
MSC is what worked for mine
Posted on Mar 18, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Deleteing songs
Use Windows Media Player - you must delete them from the computer by selecting the mp3 player - you cannot delete them from the Mp3 player itself.
Posted on Jun 07, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: unable to play all songs downloaded on sansa clip
You have to resyhnchroize within Rhapsody itself to make the message go away.
Posted on Jan 01, 2009
SOURCE: i cant download songs on my mp3?
yes
Posted on Jan 29, 2010
Why does my player choose to play songs in alphabetical order?
Delete the affected songs off your Sansa, Re-edit the id3 tags with the correct track information, then reload them onto the Sansa. also, make sure it is not on "Random" mode.
Oct 20, 2008 | SanDisk Sansa m240 MP3 Player
Unable to play all songs downloaded on sansa clip
Oct 19, 2008 | SanDisk Sansa Clip MP3 Player
MP3 files are getting copied into sansa m240, but is not playing.
To format the player directly, follow these steps:
1. Press the Home button to return to the Main Menu.
2. Select Settings from the Main Menu.
3. Select System Settings.
4. Scroll down to Format and select it.
5. Select Yes to start formatting.
Sep 16, 2008 | SanDisk Sansa m240 MP3 Player
Formatting sandisk sansa m240
how to download songs and delete the songs
Jul 05, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 is being weiiiiiiiird
I reformatted my entire mp3, then reloaded all my songs, it's normal now
Mar 28, 2008 | SanDisk Sansa m240 MP3 Player
Feb 20, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 and itunes
Probably not, try going to where the songs are all stored [My Music] select all the songs and open with the Sansa converter-to transfer music or use Windows Media Player.
Otherwise open My Computer then SansaM240 folder and drag the songs into Music.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
Sansa won't play songs
my mp3 player skips songs while playing it does'nt play the whole song it keeps skipping
Dec 24, 2007 | Audio Players & Recorders
M240 freezes all d time
I would format the device to remove all of the data and start over.
You can FORMAT the device thru My Computer>Device Name (m240)>Right Click and select FORMAT.
Best of Luck.
Nov 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
694 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
