Question about Maytag Neptune Washing Machines
F74 error code on maytag washing machine - Neptune Maytag Washing Machines
  • 3 Answers
SOURCE: Maytag front loading washing machine
This worked for me for the E3 error code: Turn the machine off and then on. Enter the Service Mode by pressing the Chime and Exrta Rinse keys for 3 sec. Display the Diagnostic Codes by pressing the Rinse and Spin key. Clear the codes by pressing the Delay and Chime keys for 3 sec. Turn the machine off, unplug and plug in the power cord. This dumps the memory. Evidently, if it gets full, it causes problems with the programming and messes up the cycles.
Posted on Jun 20, 2008
  • 34 Answers
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
Posted on Aug 13, 2009
milten1
  • 1304 Answers
SOURCE: what does error code 5ud5 mean on m odel MAH
SUDS
IT MEANS YOUR USING WAY TO MUCH SOAP
for that model you should not be using more than 1 tablespoon
let is set for an hour or so then start a full load of towles with no soap
it should be fine after that
Posted on Oct 06, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: maytag washer has error code of dc
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Posted on Sep 27, 2010
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
F74 what does this mean
.. error code f74 Water pressure switch is staying closed.
Apr 10, 2016 | Miele DG155-1 Steam Oven Single
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
My whirlpool duet washer displays an "F 74" error code. We had a power outage, the washer is plugged into a surge protector. I called whirlpool last night - they had me unplug for around 10 minutes, plug...
F74 is not a valid fault code. If it was F14, then it was bad eeprom value (on timer board).
Try tripping circuit breaker or unplugging the power cord. Connect power back and follow reset procedure again, that will reset NVRam.
Ensure that there is no water inside the machine. If there is water, while machine is disconnected, empty water.
If that does not work, the control board may be defective.
Oct 09, 2009 | Washing Machines
Whirlpool duet
F74--UI Eeprom failure
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Sep 06, 2008 | Whirlpool AWM9000 Front Load Washer
Washing Machines Logo
508 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
