Scanner kv-2065w always show error code u18, paper remain in scanner, check through but no paper remain, sensor, mother board been changed, still the same problem arises.
4 Suggested Answers
  • 16 Answers
SOURCE: Scanner No Paper Detected Error
There is a narrow FFC cable that connects the sensors between the hoppper assembly and the main scanner unit that may be loose. Check both ends. This cable can also develop small fractures over time. These fractures can cause the sensors to not be noticed by the scanner or give false info. The cable may need to be replaced.
Posted on Sep 08, 2009
SOURCE: u18 remaining doc. error code;
The sensor that you can't see (at the bottom facing up) needed to be cleaned. Once cleaned with a cotton swab and alcohol the scanner works fine.
Posted on Sep 13, 2010
hawaiianb283
  • 24 Answers
SOURCE: Error P00 on display, no paper jam found
It's going to be the sensor or the circuit board. Make sure the sensor is clear (use a vacuum cleaner with a crevice attachment blowing air should be very limited, because staples blown onto the circuit boards WILL fry them).
If the sensor is clear, then the sensor is probably unplugged; they don't go bad very often. If you don't feel comfortable taking it apart to check it out, call a tech. If you do take it apart, make sure the sensor and all cables are plugged in. If they are, you have a bad circuit board. For Canon Scanner Repair in Dallas, Texas :call Scan-R-Store
Posted on Feb 29, 2012
I have a scanner that has an f68 error. I have already followed the trouble shooting flow chart and replaced the Drive board, then main control board and the mother board and still have the f68 error. ...
Hi I dont have the manual for that exact model but if its the same as the one I have F68 refers to Front side lamp error , check the lamp/illumination if this is okay check there is probably a roller with a white area on the end that it uses as a white reference make sure this is in place and not damaged
Sep 21, 2011 | Panasonic KV S2065W Path-Through Scanner
Jul 30, 2009 | Panasonic KV-S3065CL Path-Through Scanner
Paper jam, but no paper in the machine
This one is easy, its yoru exit sensor, the only sensor in the scanner "looking" up, so dust sits on it untill it thinks its paper. slide in a cotton bud or blow air in the small recess between the 2 black exit rollers visable where the paper exits from.
let me know how you get on.
Jul 15, 2009 | Panasonic KV S2026C Path-Through Scanner
Get paper path error when path is clear & clean.
There are two types of sensors, optical and mechanical. Sometimes the mechanical sensor get stuck and give a message to the scanner that paper still remains inside the scanner. Check if any of them is stuck, Blow air from a dsiatance so that any shreds of paper is foreced out.
S. Mohan, India
Jun 22, 2009 | Bell & Howell Sidekick 1400 Path-Through...
U18 remaining doc. error code;
Apr 03, 2009 | Office Equipment & Supplies
There may be a samll shred of paper stuck in the sensor, Search thoroughly.
S. Mohan
Dec 17, 2008 | Canon DR-7580
Kodak 2500D error
I have had the same problem. That error represent a document still in the scan path. You will probably find there is no paper in the scanner. I tried this and it works every time. On the top of the scanner there is an access door. You will find this just above the discharge rollers. Open that door and either blow air in the compartment or blow hard using your mouth to clear dust. Close the door. That should resolve the problem. It is my guess that dust collects on sensors and the scanner is tricked into thinking there is paper in the path.
Jan 04, 2008 | Kodak Digital Science 2500D Path-Through...
Remove paper from scanner
I have this same problem every time I unplug my Panasonic KV-2026C. I've lost the original disk with the utilities, and the Panasonic web site says, they only provide the disk with the original equipment. You know, I'll never buy another Panasonic product. But I'm usually able to get the ready light to come back on by doing the following. I use a clean cloth that is soaked in Rubbing Alcohol (not nail polish remover, but pure rubbing alcohol). I basically open up the back, and clean each roller. There are two green tabs at the top of the back of the scanner. These need to be opened up (be careful, because the parts sort of fall out if you're not careful, and they are difficult to re-assemble). Again, wipe everything down with the rubbing alcohol. Close up the upper tabs. Make sure you wipe down the glass slits on both the door (front-of-the-page scanning port) and on the unit itsel (back-of-the-page scanning port). Before you close up the back door, let it sit for about 5 minutes, allowing the rubbing alcohol to evaporate. I also connect the scanner to the laptop and get the "blip" sound from Windows to recognize the scanner. I don't know if that's important or not. Then I say a healthy prayer, plug it back in and shut the back door. If there is a god on duty that day, the ready light comes on, and stays on as long as I have the power connected. I just went through the process and it worked!!!! The minute the power is off, the error light stays on. Good luck, my friends! Joe Diehl, Seattle WA
Dec 04, 2007 | Panasonic KV S2026C Path-Through Scanner
Panasonic Hi-speed scanner
if your positive there is no paper and you have unplugged, you can take canned air and spay it out otherwise you have a bad sensor
Nov 01, 2007 | Panasonic KV-S2026C Pass-Through Scanner
k24674
