Question about Watches
Sharp watch bands
I need a replacement watch band for my SHARP watch (SHP2084 098 PC32). What are my chances being able to find one?
SOURCE: Replacement Watch Band
I also have an Adidas watch, but cannot find a replacement.
Unfortunately, very unique for the contours around the body of the watch. Where can I find a replacement watchband?
Posted on Aug 03, 2008
SOURCE: replacement acrylic watch band
I posted the other same request...all I've been able to find is ceramic replacement bands, and nothing clear. These run about $200.00 and for that price we should just replace the watch with a "Toy" which it is copy of...
Posted on Jul 31, 2009
escapement
  • 2334 Answers
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Posted on Mar 04, 2010
Testimonial: "excellent work ! thanks a lot !"
escapement
  • 2334 Answers
SOURCE: Replacement watch band
You can buy any rubber watch strap and take the loop off for replacement. Just make sure - the strap you buy is exactly the same width as the original ******** your watch. Needless to say: colour should match as well. Rate me, plz.
Posted on Mar 30, 2010
Testimonial: "Quick and informative response!"
  • 101 Answers
SOURCE: My Casio watch band has split apart where the
are you referring to casio mtg900 if so do you mean the rubber part below the G button . If so I do believe casio sells that first link . You can call them if you would like to order it if they still have in stock or for a whole new band
you can see the parts store here
http://www.pacparts.com/model.cfm?CFID=3663724&CFTOKEN=19469938&mfg=CASIO&model_id=MTG900DA-9V&row_start=1&src_model_id=mtg-900&action=list_part
I believe the 12 h and 6 h are the parts you are looking for I am not sure what side you need 12 oclock or 6 oclock , but give them a call they should be able to help you out
the other company that handles watch parts is here
http://www.americanperfit.com/parts/parts.htm
Posted on Oct 26, 2010
Does this leather band come out someway ? I can not see any pin holes ? My Husbands wants to switch it out to a buckle clasp instead. Is this possibile with watch ?
yes
under the band at the ends there is a small spring loaded pin that is removed and the band comes out
use something with a sharp edge , press in in beside the leather and then push sideways to compress the spring and the pin will come out
or take it to a jeweller and he will remove and fit the new band in 5 minutes
Feb 16, 2017 | Watches
How can I shorten the watch band. I've tried pushing the pins, but they don;t seem to move. What is the significance of the arrows on the back of the band segments? Thank you for your help!
The arrows show you the direction to push out the pins.
  • Look for an arrow on the inside of your watch band. The direction the arrow is pointing is the direction the pin should slide out of the band. If your pin is screwed in, you may not see an arrow on the inside of your band.
  • 2 Look on the edge of the watch band for a small round object, the pin. If the pin head is flat, then it needs to be pushed out. If the pin head has a screw driver groove, then it needs to be screwed out. Depending on the type of watch pin you have, take a sharp pointed tool or a tiny screw driver from a hobby kit or watch tool kit and place it on the head of the pin. You should be looking at the end of the pin on the opposite side from where the arrow is pointing.
  • 3 Push on the sharp tool to push the pin out of the watch band. You will need to use force to push the pin out. If your pin is screwed in, gently unscrew the pin until it becomes loose. Remove the pin with your fingertips. Make sure to put the pin in a safe place, because you will need it again when resizing the watch band.
  • Aug 18, 2010 | Kenneth Cole 1213 Wrist Watch
    How do you adjust the steel watch band of a Citizen Sky Hawk A-T? JY0000-53E
      Making the Band Shorter
    1. Step 1 Stand the bracelet up on its side. Look for arrows on the inside of the bracelet.
    2. Step 2 Insert a small pointed tool from your hobby or watch set into the tiny holes on the edge of the bracelet. Insert the tool in the hole at the base of the arrow. You will see two holes on the edge of the band. Both pins need to be removed.
    3. Step 3 Push the pin out with force in the direction the arrow is pointing. Repeat this process on the second pin. When the pins are removed the link will be loose.
    4. Step 4 Remove the link from its neighbor and replace one pin to secure the bracelet.
    5. Making the Band Longer
    6. Step 1 Remove the link closest to the clasp by putting a small, pointed tool into the tiny hole on the edge of the watch band.
    7. Step 2 Push the pin out so the link is detached from the clasp.
    8. Step 3 Put a new link next to the detached link and line them up so a new pin can go through their holes and attach them together. You may need to snap them together depending on the type of Citizen bracelet you have.
    9. Step 4 Place the pin into the hole on the edge of the band and push the pin through the band with your sharp tool to attach the two links.
    10. Step 5 Repeat this process if you need to attach more than one link.
    Aug 14, 2010 | Citizen Watches
    Got a wine colored stretch band that the pieces of the band fell off
    I'm sorry to tell you there is no way you can fix it yourself. (Special tools are needed to fix). Visit your nearest watch repair shop and ask for help. note, please: As my answer is negative to you, it is positive to your bracelet (band), so rate me accordingly.
    Feb 04, 2010 | Watches
    How do I remove the back off a fossill watch to replace the batteries
    If it doesn't have the indentations for a tool used to screw off the case back then its a pry off type and you need to use a sharp tool and pry off under the case against the band post
    Nov 06, 2009 | Fossil Metal Chronograph White Dial ES1793...
    It's too small on my wrist I have the extra bands but I don't know how to add them
    you will need sharp needle nose pliers and a small ering pin (the part that goes thru the ear) use your needle nose pliers and grabing the ear pin pushe the pin that holds one of your wrist band then finish pulling the pin with the needle nose pliers all the way add the extra band and insert the pin with your fingers first then finish with pliers
    Oct 26, 2009 | Kenneth Cole KC3315 Wrist Watch
    How to replace the rubber wristband of a luminox watch
    If you have a new wristband, there is a spring loaded lug where the band joins the watch, use a sharp knife or jeweler's screwdriver to slide the lug from the watch
    Jun 19, 2009 | Navy Seal Luminox Dive Watch
    Skagen watch band issue
    You can find generic bands on Ebay or do a Google search for mesh bands. They come in various widths usually in millimeters so you have to measure the width between the lugs where the band connects to the case of the watch. Do a Google search for nomenclature of what a lug is on a watch if you do not know what I mean.
    Sep 03, 2008 | Skagen 355LGSC Wrist Watch
    Watches Logo
    20 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
