Question about Kenmore Oasis HE 27082 Top Load Washer
Whirpool washer my washer it cycles the water and spin, but wont do the last cycle, fast spinning and recycle water. I tought will be the timer, I changed the timer, but still the problem is there. any solution?
  • 15,935 Answers
Replace the lid switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
Washer fills up and starts. Once it gets to rinse cycle and spin cycle is makes a loud humming noise but wont spin. If i open the top lid and wait a second or two and close it, it starts the cycle. Been...
If you have a direct drive washer made by Whirlpool, your washer transmission has what is called a neutral drain built into it. It is designed to pump water out before it starts to spin. After water has drained out, the timer has a pause in it where motor shuts off for about 5 seconds. When motor comes back on, transmission is then in gear to spin. If timer never pauses, then washer never goes in gear to spin. Timer is most likely defective.
Sep 14, 2017 | Whirlpool WTW5100S Top Load Washer
Washer wont spin out
If your washer is not spinning you need to check this part.
  1. Test the lid switch
  2. Test the timer control
  3. Test the centrifugal switch
  4. Test the water level switch
  5. Inspect the motor coupler
  6. Inspect the drive belt(belt drive only)
  7. Inspect under the washer for soot (clutch)
  8. Test the motor
  9. Inspect the pulley
  10. Test the transmission
Mar 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a fisher paykel eco which is spining water on the floor.
You could take the pump out and check it for obstacles
Mar 05, 2010 | Washing Machines
Water pumping out at a trickle. stops in mid cycle
The timer seems to have gone out on you. Try to manually set it on spin and if that works then the timer is out.
Jun 30, 2009 | General Electric WSSH300G Front Load...
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
14 cycle front load washer fridgidaire
press cancel. (turns off washer)
press start/pause (wake up)
hold cancel and start/pause 10sec
last error code will come up.
E47 door lock error
check wires connections to the door lock..
replace door lock..
hope it helps
Aug 08, 2008 | Frigidaire ATF6000ES Front Load Washer
Ultimate II is refusing to go into agtation/wash cycle
It sounds like a bad timer unit, and possibly a lid switch.
As far as the water overfilling, that may be an unrelated problem, such as the water level switch... but most likely the timer.
I have the same model, and it wouldn't drain.. and it would try to spin when full of water... an interesting sight to see!
Jan 07, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire front load washer problems
My problem is that water is still draining when it goes to final spin. final spin is not working properly. then machine shuts itself off before timer.
Nov 16, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
