Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I would like to know where the spark plug is located Craftsman mo
On a craftsman mover LT 2000, I replaced the battery, and mower still won't start, I am thinking it is the spark plug.
Thanks,
Ron
  • rdeichelberg Jan 14, 2009
    I meant to ask where is the spark plug located on the LT 2000 Craftsman mower?
    Thanks,
    Ron
SOURCE: Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
Posted on May 27, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
SOURCE: craftsman lt 1000 wont stay running
Take a paperclip and clean out the small hole on your gas cap. And yes I am being serious.
Posted on Aug 25, 2009
  • 8 Answers
SOURCE: how to replace deck belt on lt 1000 craftsman
there are several belt guards that you will need to loosen then the belt will slip right on. having someone hold the clutch will make it easier, and the belt diagram should be on the deck. If not, these are common mowers, so a search for this or a friends/neighbors mower may hold the answer. Be sure to re tighten all guards or your belt will pop off and wear out very fast against these metal parts
Posted on Oct 16, 2009
675 Briggs & Stratton Power Propelled, Electric Start, Model 917376531. Where is battery located?
Margaret, you plug your charger into the battery, the lead or connection for charger is attached to battery and that is where battery is located. Check the attached links,instruction and guides, Good luck Battery is # 74 in link picture.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://ubermanuals.com/product/craftsman-917376531-13041
CRAFTSMAN MOWER Parts Model 917376531 Sears PartsDirect
http://lawnandgarden.manualsonline.com/manuals/mfg/craftsman/917376531.html
Craftsman Washer 917376531 Parts List
How to charge the Craftsman 650 battery start lawn mower model 917 37641
Apr 15, 2016 | Briggs & Stratton Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Lt 2000 craftsman riding mower wont start by key only jumping cylanoid
Bad ignition switch or bad solenoid (there is no such thing as a "cylanoid"). Start by testing continuity through the ignition switch and, if the ignition switch is good, replace the solenoid.
Jul 20, 2014 | Craftsman Garden
Riding lawn mover with new battery but doesn't start.
When was the last time had valves adjusted.
Jun 26, 2013 | Craftsman Garden
Fuses location for craftsman 26 hp 54" deck mower
Replace start fuse on right side of motor by oil drain plug.
May 04, 2013 | Craftsman 26 Hp 54" Deck Yard Tractor
Craftsman LT 1000 mower I am having problems with
I have a LT 1000. I drilled out the holes in the gas cap. If they plug, you will notice the gas tank gets sucked in from the vacuum.
Gary
Sep 20, 2011 | Craftsman Garden
I have a Craftsman, 6.75hp, SP, model #917.377580 lawn mower. Was running good but, won't start any more. Don't know if or where the fuel filter would be. Thinking it might be the solid state...
If you know that you have a good plug, and you don't have spark at the plug, then it is a bad Ignition Coil (Module). If you need further help, let me know.
Good Luck!
Jim
Aug 16, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Stalling Craftsman LT 1000 Lawn Tractor
I have a Craftsman 21 HP Twin riding lawn mower and have replaced both spark plugs, filter and battery. New gas. New Oil....still will not start?? HELP!!!
Oct 11, 2009 | Craftsman Garden
Craftsman LT 2000 riding mower
Check the motor of craftsman LT 2000 riding mower
Aug 25, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
412 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
