Question about Samsung Audio Players & Recorders
Home theater doesn't connect to tv
I can get everything to connect apart from playing the tv thru the speakers!!
  • 1 more comment
  • chriscarljon Mar 07, 2009
    no and i still cant get it to work
    cheers man, mines is not bluray though.
  • chriscarljon Mar 09, 2009
    looks lie i need to go out and buy the audio red & white cables - should work but i'll keep u updated
Have you emailed samsung yet?? i"m looking at the same product but heard of this problem too
Posted on Mar 07, 2009
  • derekdriskel Mar 07, 2009
    just got this back from samsung tech..please let me know if this works and how well is the sound.thanks ~Dee
    Thank you for contacting Samsung.
    Connect optical cord out from Bluray player (BDP) to the Home Theater System (HTS). Then connect red and white audio cords OUT from your TV into the HTS.
    If you have any questions please feel free to call 1-800-SAMSUNG for further assistance.
  • derekdriskel Mar 09, 2009
    have you had any luck..I'm waiting for your sucess in it before i go out and buy one..can you let me know if you have any luck..thanks ~Dee
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Mar 03, 2013 | Coby DVD938 Theater System
I only get sound thru home theater speaker not thru tv?
Check the wires from the source, are there audio hookup from source to tv or home theater to tv? you may need to run audio cables from source to home theater and to tv.
Feb 08, 2013 | Panasonic SC-HT940 System
Trying to connect a sony home theatre system so that the akai television plays through the home teatre speakers. I used an hdmi cable, but the tv still only plays threough the tv.
The HDMI jacks on the TV are HDMI in. Thus to get the theater system to play the sound, you use the HDMI out from your set top box to the HDMI in of the Sony theater system and then the HDMI out of the theater system to the TV. (Connecting the HDMI in of the TV to the HDMI in of the home theater system will not work.)
If you are watching OTA TV or a direct coax cable connection, you need to hook up the TV audio out to the home theater system audio in to use these speakers with the TV. Then you probably need to set the TV to use the external speakers. This will probably be in the Menu under Audio. (Toggle external speakers on/off)
The Akai LCT2785TA has RCA audio out (1/4" red and white jacks). If your home theater system has RCA audio in, just get a patch cable (MM ends on each side of the cable). If your home theater system only has digital audio inputs, you will need a converter. http://www.ramelectronics.net/audio-video/audio-converters-extenders/analog-to-digital-digital-to-analog/1t-ap-216/prod1TAP216.html is a link to one appropriate converter.
I hope this helps.
Oct 10, 2011 | Akai LCT2785TA 27 in. LCD Television
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
I have a panasonic viera flat panel plasma tv and a samsung 5.1 ch blue ray home theater system and the speakers work fine on the home theater system while playing a dvd, but does not work when watching...
1. The easiest solution would be to connect a stereo RCA (red and white) cable to the audio output on the back of your TV.
2. Then connect the other end to the input on your home theater system.
3. Change the home theater system to the correct input.
Feb 12, 2011 | Samsung HTC550 Theater System
I can not get any audio from the hometheatre when turning on TV only the audio is coming out is from the regular TV speakers. However when playing a DVD or Ipod the audio is coming out from hometheatre...
hi,
connect your tvs or cable set-top box's digital audio out to the digital audio input of ur home theater. the select the corresponding input in the home theator.
or connect set -top box's to HDMI input 1 of ur home theater, and connect its HDMI out to ur tv. assign the corresponding inputs for the hdmi 1 in ur home theater.
ok
Dec 21, 2010 | LG LHB535 Theater System
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Nov 06, 2007 | Durabrand HT-3915 System
81 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
