Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Can not save word documents on sandisk cruzer
dodgecharger
  • 254 Answers
SOURCE: can no longer save to SanDisk Cruzer Micro 256MB
First, have you tried it on another computer? Basically, narrow down the problem- is it the SanDisk, or something with the USB ports on your machine? Assuming it is the SanDisk, try formatting it. You should be able to format it under Windows Explorer...properties... Or, go into Control Panel... Administrative Tools... Computer Management... Disk Management If you had files on it- they will probably be history. You could Google for recovery utilities, but such getting your files is doubtful. Hope this helps!
Posted on Jul 25, 2007
remt23c
  • 78 Answers
SOURCE: SanDisk Cruzer Titanium 2.0 GB USB Flash Drive
It sounds like it is trying to use the E: drive and it is already in use? If so while you have the flash drive installed right click on my computer /click on manage / on the left side click on disk management / on the right side you should see the C: drive with other if you see the flash drive in this list with no drive letter right click on it / click on chang drive letter and give it a G: or other letter not in use. you will get a warning click ok and exit out your drive should appear. (note this is for windows xp)
Posted on Oct 13, 2007
cheap to fix
  • 404 Answers
SOURCE: I can't save a file from my Mac to SanDisk 8G Cruzer Micro USB
you have to have the cuzer mac formatted using the disk utility.
Posted on Mar 07, 2009
  • 4 Answers
SOURCE: I have a Cruzer Sandisk memory that worked before,but not anymore
Ithink the disk is damaged, you should contact sandisk local service center to see if the warranty of your disk is not void. you can use the following link to locate the service center.
http://www.sandisk.com/sandisk-support/contact-us.aspx
Posted on Sep 03, 2009
SpideRaY
  • 687 Answers
SOURCE: Unable to open documents saved on my SanDisk
Try using my auto-installer script for the excellent USBDeview+USBIDs using this you can ensure that the USB hub has found the device and created the Virtual CD drive used to run the U3 launcher. I only wrote the installer to make it easier for you all.
With this you can disable/enable install/uninstall the drivers this makes it way easier than using the Windows equivalent.
NOTE: If you have a conflict with the launcher you will probably get either error 1001 or 1010 for a full list of the known problems look here.
http://kb.sandisk.com/app/answers/detail/a_id/13
Posted on Jan 09, 2010
How do I download word documents to cruzer flash drive
From Word, use Save As.... and point the file to your USB drive. You can also open two instances of My Computer and drag & drop from the PC to the flash drive.
May 09, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Describe your 2GB Cruzer Micro USB Flash Drive (SDCZ62048A10) Hard Drive Problem my cruzer data loss
For SanDisk flash drive to save the data, use software, U3 Launchpad. This program is used to saved data, repair damaged firmware, and firmware updates.
If you use the operating system
Win XP, download the software from here SanDisk Support
Win 7, download the software from here SanDisk Support
Hope it helps
Sep 17, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My sandisk cruzer says 0bytes
OK NO PROBOLEM JUST TRY AND SAVE SOMETHING ON IT (E.G A W ORD DOCUMENT) THEN GO INTO MY COMPUTER AND CHECK THE MEMORY USED
Apr 26, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do i use this deice to save my material on it
plug in your device to the computer wait until its installed or detected by the computer
eg open my documents folder right click on the item or files you want to transfer to your Sandisk and select send to (send it to the name of sandisk)
or you can
open my computer > open sandisk window then open the my documents folder or the folder you want to copy and drag it over to sandisk window
hope this help
Sep 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to copy from a word document to the sandisk
In Word, click File.
Click Save As.
Choose the "drive-letter" currently assigned to the SanDisk memory-device.
Choose a filename.
Click Save.
Apr 02, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Jan 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I copy something from an email to a cruzer scandisk 2GB micro USB key
you just save it on your pc and then send it to your micro usb through card reader
Jul 31, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Lost word.doc while saving direct to Cruzer
autosave file is seldom saved to the data drive
will be wherever it was configured in Word,
may be the last version recoverable
in Word
goto
Tools
options
file locations
and get the location for 'autorecover files'
open explorer and the last saved file should(fingersXed) be in that folder
Oct 27, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Micro 8GB cruzer
Save all your files on your computer before doing this.
Uninstall U3 from settings on launchpad.
Format your USB. Do not Quick format.
Reinstall U3: http://www.sandisk.com/Retail/Default.aspx?CatID=1411 (only works with Sandisk)
Drag your files into the USB. No more problems!
If anymore problems, reply!
Hope this helps!
Nicholas CHUM
Apr 22, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
29 people viewed this question
Top SanDisk Computers & Internet Experts
Sandy Moore
Sandy Moore
Cleverer2
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
