Question about Pioneer DEH-2800MP CD Player
Wireing for as pioneere
Wat wires go where on a pioneer radio
  • 8,197 Answers
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
Installation wiring diagram??
No need to guess what wires go where. Buy a wiring harness for your specific year, make and model.
You make connections from your pioneer harness which are all marked, to the Harness you will purchase for your car. They cost about $20 and can be purchased at most autopart stores, or major electronic retailers.
Once you make the connections from the pioneer harness to the harness specific for your car, simply unplug your factory radio and plug in your newly wired one.
Jan 25, 2010 | Pioneer DEH-2300 CD Player
Installin used headunit in 97blazer dnt know wat wires go where?
you need wiring harness for your truck to the radio go to your local bestbuy or car audio shop then follow color coded instructions for the wiring
Aug 13, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
Jun 02, 2009 | Pioneer DEH-P4100
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Radio
color coding yellow for the ignition, red for battery, black is negative or ground the is for speakers
Apr 13, 2008 | Pioneer DEH-P6800MP CD Player
Pioneer DEH-2800MP CD Player Logo
104 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
