Question about Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television
Location of the lamp enclosure
I'm trying to locate the lamp enclosure on my panasonic dlp tv.
  • Anonymous Feb 12, 2009
    After replacing the lamp in our panasonic dlp PT-50DL54 how do you reset the replace lamp message?
Pull off the front silver panel ... it is about 3' long and about 4" wide. It pulls off easily. below this panel on your left side you will see a small black panel held in when one Phillips screw. Remove this screw and the panel will slide to your left. This exposes the lamp unit which in turn is fastened with one brass coloured screw. Loosen this screw (screw stays attached to the lamp housing) and then simply pull the lamp unit forward to remove. Word of caution ... do not remove if the lamp is hot ... wait until it cools down. This procedure sound difficult but is really quite simple. I have replaced my lamp on twice already.
Posted on Jan 27, 2009
How does a ballast for a hitachi ultravision dlp tv look
Anon, the bulb/lamp plugs into the ballast, The attached videos shows the ballast and location near the end of the video. Check the attached links. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
HITACHI how to replace your enclosure guide
Mitsubishi Toshiba Samsung DLP TV Bulb Won Turn On DIY Easy DLP Ballast...
hitachi ultravision dlp tv replacement ballast Google Search
Apr 20, 2016 | Hitachi Televison & Video
Tip
Panasonic TY-LA1001 Lamp Replacement Manual
The Panasonic TY-LA1001 is one of the rarest enclosures in the entire DLP market to find. The same applies to the manual, so we are very proud to offer all of our visitors the replacement manual for the TY-LA1001, enjoy.
here is the link so you can download the PDF
http://www.fixyourdlp.com/2010/01/11/panasonic-ty-la1001-lamp-replacement-manual/
on Mar 24, 2010 | Televison & Video
THE LAMP IS BROKEN
First of all, unplug the TV from the wall outlet.
You have a few thousand volts going through your ballast, be very careful!
It's also a good idea to let the TV cool down for a good 15-20 minutes as the bulb itself can get extremely hot.
Locate the lamp enclosure door; it's usually at the back of your television.
There is a screws on the bottom of the lamp door, remove them using a Philips screw driver.
Take the lamp door out by dismounting it from the bottom.
inside you'll find the lamp enclosure,
On the side of the plastic enclosure there is a screw that secures the enclosure, uninstall it with a Philips screwdriver.
Pull it out the old enclosure from your TV and slide in the new one.
Reinstall the screw on the lamp enclosure.
Place the lamp door back in its place.
Secure it tightly with the screws on the bottom of the door.
Take care and good luck
Oct 09, 2010 | Panasonic PT-61LCX70 61" HDTV
II CHANGE MY LAMP AN ENCLOSURE AND NOW I HAVE GRAY DOTS WHY?
maybe it is dust..
you try to clean it?
and it looks like the DMD. to.. can you take a picture of you TV?
Jan 25, 2010 | Samsung DLP HL-P5663W 56" TV
Where is ballast located
FOX has Lamp for $109.00 1-800-227-5369
Encompass Parts has Ballast $54.43 1-800-638-3328
Encompass wants $150.00 for lamp Your TV is a Samsung it will be on Right Hand Side of TV and I would Just Replace The Lamp First? What was your TV doing to begin with?
Dec 31, 2009 | Televison & Video
My lamp light is on. can i change it myself ?
Hi your part number is TYLA1001 found it here : http://lamps-dlp.com/ProductDetail.asp?PartNumber=TY-LA1001&A=G&B=LA1001 It should be around the back.
Oct 01, 2009 | Televison & Video
The picture on the tv goes off and on but the sound stays on. after it does that for awhile it will work fine for quite some time and then it will do it some more.RCA DLP
The lamp already need replacement.To replace your lamp you need:
  • OEM RCA DLP lamp
  • flat-head screwdriver
  • T-10 & T-15 torx driver
  • pliers.
Steps: Use a pair of latex gloves.
  1. Locate the lamp through the rectangular at the back of your TV.
  2. Loosen the screw with your flat-head screwdriver.
  3. Use the two "clips" to open the compartment door.
  4. Loosen the screw on each side of the lamp enclosure.
  5. Gently pull back the tray to remove the lamp.
  6. Visually inspect the area labeled “Clip.” They are on the top and bottom of the enclosure. Between them, there is about a 3′ gap where you need to push in with your thumb to be able to pull out the rear lamp cover.
  7. Unscrew the lamp connectors with your pliers and torx driver and remove the three screws.
  8. Replace the old lamp with the new one. Be sure to put the washer back and all other parts properly.
  9. Reinstall in reverse order.
Aug 17, 2009 | Televison & Video
I need to replace the lamp...how do i get it out?
Hi, well your TV uses the lamp enclosure TY-LA1000, here is a link where you can find the manual of how to get to the enclosure http://www.fixyourdlp.com/blog/2007/09/17/panasonic-ty-la1000-enclosure-replacement-instructions-guide/ and here is another one to replace the lamp on the enclosure http://guides.fixyourdlp.com/panasonic/TY-LA1000.php
Jun 27, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic DLP
If it has "Popped" then I would expect a rather catastrophic failure, and Lamps don't go "Pop.. they just fail more likely a Capacitor, Resistor, maybe even a semiconductor... so it's off to a reputable repairman get a "quote" and proceed from there.
Jul 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50DL54 50" Rear Projection HDTV-Ready Television Logo
150 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
