Question about Dell W4201C 42 in. Plasma HDTV
Dell w4201c burning fuse...
Hello, I just bought a plasma tv with power supply problem..I have replaced the fuses but when I press the button to on, it just burn the fuse immediatelly... what should I do? buy new power supply or check the voltage of everything?? please let me know... thanks a lot, vand..
  • 2 more comments
  • vprado Jan 11, 2009
    could you please tell me how to trace the circuit board? when I replace the fuse and connect the cable supply i see a small green light on the board... when i push the button to turn the tv on, it burns...I am checking the va,vsc,vset,vscan,vg voltage, and looks like it is ok..with low voltage.. but I still have no idea what is causing fuse to blown/burn .. I am affraid to buy a new power supply board and still get the same problem... any idea what should I do?? thanks a lot, vand.
  • vprado Jan 12, 2009
    Thank you so much for your help, i will buy another power supply and see if it resolve the problem..vand.
  • michaelforti Jan 28, 2009
    I'm looking for a power supply for a dell W4201c Plasma T.V. Anyone know where i can get one?
    New Friend:
  • 90 Answers
Check the voltages, on the settings that are listed on the sticker top right they are va, ve, vset, etc.. take the black lead, and ground it. take the red tip and test each setting located on the power board. if there are more than 2 mismatches, its the power board. make sure ur ground for safety precautions.
Posted on Apr 16, 2009
    Novelist:
  • 152 Answers
Hello, definitely if your fuses are blown and your not able to circut trace and find the fualty compnents on the pb then repalce it with a working power supply this may help but also keep in mind you may want to check everything out first get your models service manual so you can verify voltages at test points. something is cuasing the fuses to blow so if you do change the power board and you blow the fuses again then you will need to trace the circut and find out where the short is and what panel or part is cuasing it .
hope this helps
Posted on Jan 10, 2009
  • charlie rodriguez
    charlie rodriguez Jan 12, 2009
    hello, at this point the supply is known to be fualty dont be scared change it. i had a similar problem with my panasonic 42pz700u plasma, no picture and red power light came on nothing else i changed the board and it back to normal.usually the power supply feeds all the boards if theres a fualt in the power board you get no picture change it out see what happens. you can find one online for cheap at auction sites.
    your question about tracing the circut you would need a service manual for your model tv, i only have panasonic and a few other manuals i dont have your model number.
    but you can find a manual at a online manual download site do a search for your model number service manual some are pay sites so search around i had to pay for mines it was about 25 bucks..
    so to trace your power supply you would need your power supply schematic and that is in the service manual..
    there are allso some fault repair tips for your particular model
    like i said you need your service manual for this..
    good luck hope this helps
4 Suggested Answers
  • 3940 Answers
SOURCE: Is Dell W4200HD Y-Main board and Dell W4201C HD Y-Main board compatible
The port locations do not seem to line up the same so I'm pretty sure they are not interchangeable
http://support.dell.com/support/edocs/systems/w4201c/om/OM.pdf
http://support.dell.com/support/edocs/systems/W4200/W4200UG.pdf
It can be worked on by a local TV repair, then TV was made for Dell by Philips
Posted on Jun 13, 2008
praky16
  • 744 Answers
SOURCE: No picture or sound on Dell w4201c plasma tv
hi its right time for u to go for a replacement of new plasma screen... its available in dell shops... bcoz repairing might cost u heavier...
thank u rate me
Posted on Feb 09, 2009
  • 132 Answers
SOURCE: My dell 50" plasma tv had a blown 8amp fuse on the
Replace the power supply board.
Posted on Aug 23, 2010
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Hello, when I turn on my LG 42 Plasma TV, triggered switches and burned out the fuse and power cable to the TV
hello, there's a possibility that the power supply has burn't out or a circuit board connected to the power supply
regardsshaun
May 11, 2012 | LG 42LB2R 42 in. LCD HDTV
My Dell Plasma W4201C will power on but has no picture or sound.
Your MOBO or your video card is likely burn.So you will need to troubleshoot the MOBO first and the if no solution or MOBO is fine do the same with the video card.
Sep 27, 2011 | Dell W4201C 42 in. Plasma HDTV
DELL PLASMA
Most cases the Y-SUS, Y upper buffer, and Y lower buffer is the problem. The replace the 3 boards are located on the left side of the chassis when you open up the TV. 90% of the time this will solve the problem.
Look for burn marks on the upper and lower buffer boards (mostly around the chips with the heatsinks on them).
Apr 01, 2010 | Dell W4201C 42 in. Plasma HDTV
thank u rate me
Feb 09, 2009 | Dell W4201C 42 in. Plasma HDTV
No Picture
Hello. It looks like I have the same problem that you had with your Dell W4200HD.
Where did you find the new power supply for yours?
Also, did you determine that you didn't really need a new power supply and that it was just a connection problem? If yes, could you please give me some help with what you did to get yours working.
Also, do you still have the power supply you took out of your TV? If yes, would you be willing to sell it to me?
Thanks in advance for your assistance.
Rocky Pruitt
rjpruitt@rjpruitt.com
Dec 26, 2008 | Dell W4201C 42 in. Plasma HDTV
Buying Dell Power Supply for 4201C Plasma
You can get it from guy at
plasmatech@gmail.com
He has everything for Dell TVs!
Nov 19, 2008 | Dell W4201C 42 in. Plasma HDTV
Power Supply
bad power supply take it to a repair center cost about 30-60
Aug 31, 2008 | Dell W4201C 42 in. Plasma HDTV
Dell W4201C 42 in. Plasma HDTV Logo
369 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
