Zanussi zwf1220w. won't spin and door won't open
It washes but does not spin and then the door will not open.
  • 1294 Answers
SOURCE: zanussi washing mashine
Plug off the wall. Open up behind, you will find a thin tube, maybe tranparent or black coming down from the control panel to the exit area (pump area) of your machine. Carefully disconnet this from above and blow into it, it should be free, if not clear it, if kinked or broken replace.
If this does not work, its your solenoid valve at the entrance point of your machine, top right, where the water is received. Just change this. If all works fine rate me please.
Posted on Dec 27, 2007
miket756
  • 2702 Answers
SOURCE: my zanussi jetsystem timeline 1600
there is a program fault on the bord,,,
Posted on Aug 30, 2010
  • 6277 Answers
SOURCE: after a wash door will
I would gently suggest as a first step (sorry but no promises!) that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Apr 07, 2011
  • 13 Answers
SOURCE: My clothes are wet after
check the brushes on you motor
Posted on May 12, 2011
  • 16 Answers
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
Posted on Jul 14, 2011
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
Door opens mid cycle??!
This video will show you how to open your Zanussi Progress ZWG3121washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2013 | Zanussi Washing Machines
Zanussi zwf1220w
Pressure system fault probably
Jun 17, 2013 | Washing Machines
Why it doesn't spin
almost all washing machines have a special switch to turn off or don't let spin when door is open. If machine 'thinks' that door is open, won't spin. "" Danger, Will Roberson...Danger..."" If you don't know what U are doing, please get help. An open switch looks like door is open.The switch is INSIDE the body of washing machine, ON the door is a plastic piece that pushes the switch lever in. You have to place 'jumpers' across the contacts on switch,shorting switch and turning machine to spins cycle.
Feb 16, 2013 | Washing Machines
Zanussi fj12544 fills but won't wash
see this probably cause:
t doesn't pump or spin
frozen pulley or broken belt, replace
It pumps, but doesn't spin
lid switch defective,motor coupler defective,belt broken,clutch broken,drive motor defective.
It spins only with the lid closed
lid swtich defective.
Jun 18, 2012 | Zanussi ZWF1420W Front Load Washer
My zanussi zwf1221w won't stop spinning. Any ideas
Check for a blocked filter. Or it could be your pump thats failed.
Mar 30, 2012 | Zanussi Washing Machines
Our Zanussi FS1455W ocassionally stops with 'End' light lit and 'Door' light lit, washes OK but does not drain/spin. All lights flash at this point. When we turn control knob to spin it...
I suspect there is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 04, 2011 | Zanussi FS1455W Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
