Epson RX585 puts no ink on the page
I have an Epson Style Photo RX585It has stopped printing properly. When I print a test page, I get no ink on the paper at all.Cartridges are all high or full - black is brand new.Complete loss to understand. I can send a test page from the PC, and I can also use the flat bed copier, either way the paper gets pulled through in the normal way, but not a dot of ink to be seen.I think the word 'help' comes to mind...
    Sergeant:
  • 431 Answers
May be problem with the print heat check it out
Posted on Jan 10, 2009
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
My Epson Workforce 1100 suddenly stopped printing black when printing in color. This happens when printing from Microsoft Word, Wordpad, Lightbox (photo manipulation) and Adobe Reader. It prints black...
normally most printers even like mine an epson NX110 will use color then black when using text but with grayscale only your forcing it to use black ink more and no color ink set in normal mode some color ink does get used ironically but it is normal for it to use color some as it reserves the black ink being used
Apr 22, 2017 | Epson WorkForce 1100 Wide-Format Color...
Epson stylus photo rx585
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 11, 2013 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson t60 is good printer ?
Hi global_sreek,
EPSON is Super fast, affordable & powerful for all your professional photo printing needs.
Features
Increase your productivity with super-fast print speed
• Print instantly from your computer screen at a fast print speed of 12 seconds per 4R photo
Maximise savings with Epson INKdividual™ Cartridges
• Maximise savings and minimise wastage by replacing only what you need
• Epson 6 colour photo ink is highly affordable, keeping daily running costs low
Perfect printing onto CDs / DVDs
• Print directly onto the printable surface of your CDs/DVDs
Compact size to fit any space
• The Epson Stylus® Photo T60 is so compact, it takes up little precious studio space,
freeing it for other uses
Photo perfection with Epson Creativity Suite
• A powerful photo editing software that lets you perfect your photo prints with just one
click of a button
SPECIFICATIONS
Print:
Ink System - 6-colour
Ink Type - Photo Dye(??¥?œ¬??ž?®??š??¼??¸????₪œ?´¢ )
Max. Print Resolution - 5760x1440 dpi (with VSDT)
Min. Ink Droplet size - 1.5pl
Print SpeeD - Approx. 37ppm (Black) Approx. 38ppm (Colour)
Connectivity and Compatibility:
PC-less function - No
Index Sheet - No
Connectivity - Card Slot - No
Connectivity - USB Cable - Yes
Connectivity - Wireless - No
Interfaces - USB 2.0 Hi-Speed
OS Support - Windows 2000/XP/XP-x64 Edition/Vista Mac OS 10.3.9 or later with USB
Network - No
Adobe Postscript - No
Memory Card Backup - No
Ink Cartridges:
INKdividual - Yes
Ink Cartridge Model - 85N Ink Series (Standard Capacity)
Media:
Media Model - S041926E1; S041927E1; S041863; S041464E1; S041285; S042070; S041925; S041332; S041786, S041259
Paper Handling:
Max. Paper Size - A4
BorderFree - Yes
Max. Paper Capacity - 120 sheets
Roll Paper - No
Tractor Feed - No
Cartridge Model(s):
85N (Standard Capacity Black Ink) - Approx 540 pages (ISO/IEC 24711 and 24712 Test Suite)
Page Yield (pages):
85N (Standard Capacity Colour Ink)* - Approx 860 pages (ISO/IEC 24711 and 24712 Test Suite)
Hope it helps.
Thank You for using Fixya.
Sep 07, 2011 | Epson TM-T60 Printer
Our printer wont print out papers because it says its low on ink but we've bought ink and put it in, but it still wont print
Have you tried printing a test page from the printer itself.
There must be a menu on the printer through which you can print a test page or alignment page.
If it does print through that then it means that the printer is fine and there is some software glitch in the computer which needs to be fixed. But if in case it does not print anything at all through that as well then it means that there is something wrong with the hardware of the printer and needs to be taken care by Epson itself.
Feb 13, 2011 | Epson Stylus C88 InkJet Photo Printer
The printer is only printing in two colors and only in lines going across the page. not a full print
Make sure that the ink you have, is Epson Ink.
I bought a compatible, supposely ink, and when I put it in, Colors did not come out the same. Lines and words, did not print out properly.
So I threw the ink cartridges, and bought original, Epson Ink, and Ooh-LA-LA, Printed out just fine.
Go Figure.
Good Luck
Nov 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
Aug 25, 2008 | Epson Stylus Photo R800 InkJet Printer
Epson photo 1400
seth, did u figure this out since last month? I am looking for the same, a print server that works with the epson 1400. is it too new on the market for any print server to know whether it works?
Oct 26, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
145 people viewed this question
jasbo
jasbo
