How do i replace a thermocoupler on a wv8840?
I can't find any clear instructions on how to remove the thermocouple on the water heater can you please help me?
Therinnaiguy
  • 1420 Answers
SOURCE: whirlpool water heater thermocouple
Nope, turn off all gas to the heater. Remove the enclosure containing the burner. Disconnect both the gas line and the thermocouple line from the gas valve and pull out the whole burner assembly. Take a pair of needle nose plyers and remove the thermocouple from the pilot assembly. Install the new one and reverse the removal procedures to put it all back together. Check to make sure there is no gas leaks and this is important, The nut to turn off the burner tube from the gas valve is reverse threads. Righty to turn off, Leftie to tighten.
Posted on Nov 21, 2007
farfield
  • 462 Answers
SOURCE: thermocouple replacement
Maybe you need to approach it differently. Why do you assume you have a bad thermocouple each time? If its because the whole flame goes out and you have to relite it, a lot of things can cause that.
1 ohm out a new thermocouple and record the ohms reading (read tween the center LEAD looking area on the end going into the gas valve and the outer shell (copper colored cover) If its a MV type controls it will have 2 wire ends. With the flame running now check the MV-DC on the same area, as the resistance. Yes you will need 2 hands extra for holding the flame on. It wont stay on without being hooked up. Typically you need 400MV for a thermocouple and 600 is the stahdardf output on a generator with wire leads depending on which you have. If your below these ranges You need to blow out the piulot area with compressed air and retry it. You should get an increase in the milli volts after cleaning because now the flame will hit the pilot or thermocouple or generator as designed and dust was causing it to be lazy and not get enough voltage back to the gas valve to stay on.
Now this is assuming you have the correct pilot orfice and its not too small like with an LP orfice installed on a NG system. The pressures are differant and the hole is way smaller on LP.
This is a really common problem with multi changeouts of thermocouples. Dusty Pilot burners. y policy has always been to blow it out first after observing the type and kind of flame. Then reexamine it after cleaning it out.
If this helps you please rate me as high as you can. If I have not given you enough information please post back so I can better aquaint myself with you problem. Good Luck!
Posted on Mar 23, 2009
  • 1214 Answers
SOURCE: Is it o k to bend the thermocouple tip. The only
Bending it will ruin it. You need to find out why the pilot flame is not as strong as it should be.
It is usually caused by bugs or spiders having gotten into the small air mix jet of the pilot assembly and died or built a web or, there is some dirt from the fuel that is partially clogging the fuel tube leading up to the pilot assembly, or plugging the orifice.
Posted on Dec 14, 2009
Testimonial: "worked perfectly"
SOURCE: whirlpool gas hot water heater thermocouple is bad
HELLO.. "ALL' THE WHIRLPOOL GAS WATER HEATERS SOLD BY LOWES ARE JUNK...THEY HAVE A DESIGN FLAW...THAT KEEPS THE PILOT LIGHT FROM STAYING LIT...MANY LAWSUITS TO BOTH LOWES & WHIRLPOOL...THIS HAS BEEN GOING ON SINCE 2000 ....TO SAVE YOU THE MOST AGGRAVATION & TIME...REPLACE THE HEATER WITH A "DIFFERENT" BRAND..ANY REPAIRS WILL FAIL AGAIN ...WHIRLPOOL & LOWES ARE "NOT" SATNDING BEHIND THESE ....YOU WOULD THINK IN 9 YEAERS...WHIRLPOOL COULD RE-DESIGN THESE TO MAKE THEM RELIABLE....BUT...THEY HAVE BOTH CHOSEN TO DO "NOTHING".......
Posted on Dec 16, 2009
SOURCE: have to tape thermocouple button in for heater to
Reddy Parts has one for $25.
Posted on Dec 21, 2009
How do I replace a thermocouple?
Need the make and the model number of the heater.
Sep 29, 2016 | Water Heaters
Model number is bfg1a4034t3n0v
Todd, Check the attached links,instruction and guides for water heater thermocouple and gas valve. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Hot Water Heaters How to Install Thermocouple on Water Heater
http://www.familyhandyman.com/plumbing/water-heater/how-to-replace-a-water-heater-thermocouple/view-all
CTRL TV Volume 1 Introduction to the problem and troubleshooting Gas Water...
gas water heater parts diagram Google Search
Apr 26, 2016 | Water Heaters
How to replace thermocouple in 42v50-50f
Copy following link:
http://waterheatertimer.org/How-to-replace-thermocouple.html
Rheem 42V50-50 is ordinary atmospheric-vent gas water heater with mechanical (non-electronic) gas control valve, which says that unit has ordinary thermocouple, and not thermopile.
Buy generic thermocouple from local hardware.
To replace the thermocouple you need to remove entire burner assembly from water heater, and have replacement Burner access door gasket on hand. 1-800-268-6966
Combustion door held in place with tamper-proof screws
Since the water heater problem may be more complicated than just the thermocouple, and water heater flame arresor screen may need to be cleaned, and burner parts cleaned, door gasket replaced, and gas pressure checked, and piezo electrode checked, it might be best to have qualified service technician do the work for $300.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 28, 2012 | Rheem Water Heaters
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
Apr 21, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I WOULD LIKE TO REPLACE MY THERMO CUPPLING
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afeavw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Begin this project by shutting off the gas control knob on your hot water heater. Once you are sure that the gas is off, you should use a wrench to remove the nut that attaches the thermocouple to the gas hot water tank. This nut should appear to be securing a piece of copper tubing or other type of tubing. With the nut removed, you should also pull down on the tubing, dislodging it from the thermocouple.
Sometimes there is another nut that attaches the end of the thermocouple to the pilot bracket, if this is the case you should unscrew this nut as well. You can slide it down the tubing and keep it there until you need to replace it.
With the nuts that were holding the unit in place removed, you should be able to slide the old thermocouple out of the brackets that hold it to the hot water heater. You should then take it to a hardware or home improvement store and find a suitable replacement. Then follow these steps to install the new part and fix the hot water heater.
To change the thermocouple, you should press the end of the thermocouple into the pilot bracket as far as you can. If you had to remove a second nut to remove the old thermocouple, now is the time to replace that nut securely.
With the thermocouple in place, you should connect the lead to the control unit. Use the nut you removed in the beginning steps to secure the lead. You should then tighten it at least a quarter turn with a wench to make sure the lead is securely attached to the control unit of the gas hot water heater.
Now that the new thermocouple is installed on your gas hot water heater, turn on the gas shut off valve that you turned off earlier. You should be able to relight the pilot and the functionality of your gas hot water heater should be restored.
Dec 06, 2010 | Heating & Cooling
Our Bosch model AQ 125 Bong water heater pilot light will not stay on. We've tried numerous times. The instruction suggest a service technician. There are none available in our area. What the best...
It sounds to me like your thermocouple is bad . See if you can trace it from the gas valve to pilot light. Remove thermocouple and try to get a exact replacement part. If the length varies don't worry about that. Install new thermocouple and see if that doesn't solve your problem. Thanks
Dec 01, 2010 | Bosch & Tankless Water Heater
I have old rheem ruud hot water tank. it's down for 4 day's, i would like to get it started, but the thing i would like to find out is can i get it going by lighting it up by using lighter or not. The...
Yes you can light it with a BBQ type lighter (long enough).
If it lights and stays lit then you need to change the thermocouple (looks like a little pipe off gas valve)
In simplest terms, a thermocouple is a temperature sensor. Normally inexpensive, a thermocouple is standard on hot water tanks. If your thermocouple breaks or you feel it is not working properly, consider replacing it b?p=y23r90wnbq7oglkvtnbuhgyhrktxauzqpeoaddsf&t=18g7grtjm%2fx%3d1290445898%2fe%3d2143440281%2fr%3dacont%2fk%3d5%2fv%3d8.1%2fw%3d0%2fy%3dyahoo%2ff%3d2680761980%2fh%3dcg49imfjb250iibzzxj2zulkpsjzmjnsotb3tkjxn09nbgtwve5ivuhnewhys1r4yvv6cxbfb0fezfngiibzaxrlswq9ijq4mtmwnteiihrtdg1wpsixmjkwndq1odk4ota5njiwiia-%2fq%3d-1%2fs%3d1%2fj%3d6f060d4c&u=13gohjn6b%2fn%3df8a.bkwnpkw-%2fc%3d715481.14405591.14260180.13829426%2fd%3dlrec%2fb%3d6235626%2fv%3d1 lg.php?category_id=6&content_type=article&content_type_id=584031&key_page=1721642411054458764&site_id=1&bannerid=10089&campaignid=2945&zoneid=2&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html%3fcontent_type_id%3d584031&cb=ebe6534afe avw.php?zoneid=2&cb=1721642411054458764&source=&n=a14de4a9&slice=-1060-&dma=-0-&cty=-us-&content_type=article&content_type_id=584031&category_id=6&key_ad=1045292919&site_id=1&ad_pos=2&key_page=1721642411054458764&ac_url=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f584031%2fhow_to_change_a_thermocouple_on_your.html rather than installing a new gas hot water heater.
Nov 22, 2010 | Heating & Cooling
The pilot light on my gas water heater continually goes out. I can re-light the pilot and get it going. The gas burners goes on runs for awhile. I'm assuming when that when the temp hits the desired temp...
getimage_new.asp?id=599586&imagetype=2&noimagetype=2&colorimagesize=2
The pilot assembly should look similar to the pic above. Depending on where you live, you may be required to hire a certified plumber to replace the parts. If not you can do it your self. Keep in mind if it's not staying lit you also need to check the thermostat and the thermocoupler before replacing the pilot assembly. There is a good chance it is just the thermocoupler going out. It is one of the first things to check when troubleshooting a pilot light problem with a gas water heater. A thermocouple determines if the pilot light is lit. If it's not lit, the gas valve fails. If that's the problem, replace the thermocouple.
  1. Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  2. Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  3. Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  4. Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  5. Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
Jul 09, 2009 | Northern Tool Water Heaters
Heating & Cooling Logo
237 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
