Question about Pioneer Elite Vsx 03txh 7.1 Channel 770 Watt Receiver
VSX-03TXH HDMI inputs not working
DVD or Blu-ray HDMI input does not work in Pioneer receiver.
  • joshua499
    joshua499 Nov 29, 2012
    The setup on this system is that the TV is being fed video using HDMI Baluns and 2 CAT5E cables. The Pioneer VSX-03TXH feeds the baluns. We are wanting to utilize a complete HDMI solution but the Pioneer will not pass any video player feed through the HDMI ports it has. Once the ports are configured, the TV cable receiver is used to tested connectivity and then the DVD or Blu-ray players are connected using HDMI cables. No video/audio with the DVD/Blu-ray but the cable receiver works properly.
  • joshua499
    With the Pioneer's HDMI out feeding the video to the HDMI baluns, using the component inputs to receive the DVD and Bluray video induces snow on the TV.
My hdmi is on my pioneer vsx 523
The HDMI inputs are on the back upper left of the unit. the 4 on the left are INPUTS (like you connect you DVD to port 1) then you need a 2nd HDMI cable from the white 5th port going OUT to your TV HMDI port.
http://www.pioneerelectronics.com/StaticFiles/PUSA/images/Product%20images/Home/VSX-523_back.jpg
Dec 07, 2016 | Pioneer Audio Players & Recorders
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
I have a pioneer VSX-72TXV receiver, and when I switch to my Apple TV, Radio or DVD the audio does not work, but the video works properly. Also, if I only keep the system on cable TV, the video/audio...
I would check your input settings. If everything is hooked up through hdmi, make sure that those inputs are set for hdmi audio, not digital or analog. If it is a setting problem, you might be able to reset the unit and fix it, but you will lose any settings that you may have had for other things.
Sep 22, 2013 | Pioneer VSX-92TXH Receiver
I am trying to hook up my Pioneer vsx-455 to a LG LED LCD TV. I am not sure on how to do this and I can not find a manual anywhere. Can you help me?
your reciever does not have hdmi, so the audio is not going to be true DD+ or DTS for broadcast tv.
if your dvd/blue ray player has digital optical spdif, this can be used to transfer the encoded DD+/DTS digital audio.
the besat way to run your tv audio through the reciever is to hook up the dvd/blue ray player up with (perferrably) digital optical spdif, composite spdif or (least favorably) through the stereo stereo analog inputs on the reciever for "dvd" audio in and hook the video from the dvd/blue ray up to the corresponding "dvd" video component input on the reciever.
this way is only going to get your dvd/blue ray sound, next you need to hook up your cable box to the reciever so that you can get broadcast tv sound. hook up the cable box audio to the "tv" stereo analog audio ins, and hook the video to the corresponding "tv" video component inputs.
the component video inputs have separate jacks for red, green and blue ( labeled "Y" "Pb" and "Pr") and are capable of carrying a 1080p full hd signal. use the component video outputs on the reciever to output the video signal to a component video input on the tv, using the receiver's input selector to change the video source.
Nov 25, 2010 | Pioneer VSX-455 Receiver
Recently purchased this reciever, and in reading the manual, I cannot tell if it will work if I hook my Comcast HDMI to one of the HDMI inputs (Input 2)? In general, i will be only hooking up the Cable box...
It should work fine. The Pioneer VSX 1019 AH-K has been made so that it can accept 4 HDMI inputs (of which 3 are assignable, and 1 is for the BD player)
If you still have a problem, you can resort to the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. A lot of helpful guys out there, and a very active thread.
Oct 27, 2009 | Pioneer VSX-1019AHK A/V receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
How to connect pionier VSX-918V-K receiver with blu-ray dvd and high definition tv box
The audio OUTPUT of blu-ray dvd is to INPUT to the VSX-918V-K receiver.There are three RCA jack red and white is the audio,the yellow or blue sometimes for the video connect to your TV...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 23, 2008 | Pioneer Audio Players & Recorders
HELP Blu-Ray to Pioneer DVD Suround System connection
The receiver that came with your speakers should have a digital input for a dolby digital source. On the back of the receiver it's probably labled "digital coax" or it could be an optical as well.
Your new Blu-Ray has these outputs on the back. it's as simple as getting the correct cable and selecting that input on the receiver.
To make sure you get the right cable, look at the back of the receiver, and the blu-ray. Look for the digital input on the receiver, and get a cable that matches that. It's either a single RCA cable, or an optical.
So when done, you will have the HDMI or Component out from the Blu-Ray going to the TV, and the digital audio going to the receiver. To hear the sound through the receiver, just go to that input on the receiver.
Dec 23, 2007 | Pioneer HTZ-55DV System
HDMI Compatibility
It sounds to me like you have a HDMI Control issue. It sounds like the DVD player wants to control the receiver. Try turning off hdmi control on the TV, reciever, and the dvd player in their setup menus.
Let me know if this helped,
Joe
Oct 03, 2007 | Pioneer VSX-81TXV Receiver
Pioneer Elite Vsx 03txh 7.1 Channel 770 Watt Receiver Logo
111 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
