Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
Craftsman snowthrower will not throw snow
Model 536886260 the augar is spinning but stops when snow gets in the shoot. Is there a belt slipping?
I have the same machine and it sounds like the belt is indeed slipping.  If the belt is not worn or stretched too badly, you can perform a small adjustment on the idler-wheel (the thing that controls belt tension) by sliding back the plastic cover on the spring that is attached to the bottom of the lever-cable and tightening the nut so that there is less slack in the cable.  If the nut is all already all the up, then you need to replace the belt, which can be easily accessed by removing the plastic cover in front of the motor under where the spare shear pin compartment is located.  There are two bolts (one on each side) that need to be removed and then the cover just pulls off.  This will expose both belts.  The front one is for the auger drive and the rear one is for the wheel drive.  The belt can be easily replaced without any further dis-assembly by simply removing and replacing it in the reverse manner.  Don't forget to readjust the spring so that excessive tension is not applied to the new belt.  Hope this helps.
Posted on Jan 20, 2009
Snow keeps getting stuck & doesn't shoot out, even if the snow isn't heavy, after several
View Comment - MovingSnow.com
movingsnow.com/.../craftsman-88395-30?-277-cc-two-stage-snow-blow...
Oct 14, 2015 - 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer at $1049 (minus ... If you do get something stuck in the front end - yes it will slip the belt.
Cheap 2 stage Snow Blowers - There are a few good ones ...
movingsnow.com > ... > 24 in Craftsman 88172 179 cc
Nov 7, 2014 - Sears carries other brands besides Craftsman but they are all not as good of ... Briggs and Stratton 1696610 Dual-Stage Snow Thrower with 208cc ...Subscribe to our mailing list and get interesting stuff and updates to your email inbox...... up to the 28 inch 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer.
Dec 29, 2015 | Craftsman 28 In 277cc* Dual-Stage...
Why can't I tighten the drive belt enough to keep snowthrower throwing snow? .
Perhaps the drive belt has been over stretched, meaning you need a new one...
Oct 13, 2015 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
I have a Craftsman 9hp snowblower and it is not blowing snow. Both shear pins are intact but the 2nd stage auger does not seem to be spinning to throw the snow through the chute.\r\nIs there a belt or...
It is belt driven, the belt is located between the chute and the engine behind the inspection cover some have it on the top and some on the bottom.That model may have to be split in half to get the belt past the shaft.But regardless it can at least be inspected by taking the cover off.Please let me know if this helps
Jan 19, 2011 | Craftsman 16" High Garden Tractor Snow and...
Have a craftsmand 24" snowthrower
If the motor runs well, the two most common causes of this are the drive belt is worn and/or the shear pins are broke.
If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belts.
Your operator's manual will show you how to remove the cover and check/change the belts.
If you don't have a copy you can get the manual through managemyhome.com
You will need the model number off the snowblower. It is usually located on the bottom right hand corner of the frame (from the handle side)
The model number looks like 247.123456.
The belt closest to the blower assembly drives the auger/blower and the belt closest to the engine drives the transmission. It sounds like you need to inspect the blower belt.
With the engine not running, have someone depress the drive lever and check the belt.
You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced.
On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt) It may be torn and broke completely.
Replace the belt if it is worn, stretched or frayed
The shear pins are located on the auger in the front of the machine. Your newer Craftsman has four. If you don't now about them look in your operator's manual for the location. You need all four for the snowblower to work well. Replace the missing ones.
You can get parts for you Craftsman and most MTD made models through searspartsdirect.com. With other makes you can get parts through jackssmallengines.com
If you are unfamiliar with repairing machines you can get your snow blower repaired by taking it to your local Sears.
They will have a technician troubleshoot and repair the unit.
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Craftsman Garden
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
Model 42 snowthrower throws more belts than snow.
what might be happening is that somthing is seezing as you are using it, a smoking belt meens that either the motor has seezed at some point and has burnt the belt, this in turn has made the belt thinner so will slipp allot, but i think the main problem is a bearing is seezing when it gets hot, thats possibly why it last a while then runs the belt, move the pullies in and out up and down to see if there is movement in them if there is they will need replacing, also feel if they are smooth when turned by hand, listen to them and see if you can hear a bit of graunching this is also a give away that the bearings are u/s...hope that helped
Feb 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
I have craftsman snow blower 5 hp 24inch model #
does the impeller spin and not the augers.if so check sheer bolts.if neither impeller or auger spins check auger belt.
Feb 22, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
255 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
