Question about Midland 1001Z 40-Channels Base CB Radio
Cu respect va salut din romania ,am o intrebare ea este pa fm ca frcventa ca la noi nu merge
Salut statiea radio cb 1001z este pe frcventa fm ptr romania adica merge si la noi in tara.
4 Suggested Answers
wyoed1
  • 211 Answers
SOURCE: 75-822 midland radio
You have a bad detector in the radio. Needs serviced. Change the bad detector diode and it should work. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
  • 38 Answers
SOURCE: My Midland 1001Z 40-Channels Base
Your best bet is to take it to a tech and let him fix it. Popping a fuse means there was an "overload" of current or a "dead short". neither are good and can cause a fire either in a vehicle or home. I use a Mirage 66 and an RCI-2950 (mobiles) as my base stations. The only difference between a base unit and a mobile unit is "how you power them up" (obviously). I use a 6 amp power supply.
Once again.........if you are not knowledgeable, take it to someone who is. It may save your life, home, and/or vehicle! DO NOT TAKE CHANCES!!!
"WILDCAT" IN LAURELVILLE OHIO
35 years in the cb world!!!
Posted on Dec 30, 2010
SOURCE: i cant be heard when i speak through my midland
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Posted on Mar 29, 2011
Salut nu merge abs la opel vectra a 94 poate cineva sa ma ajute
Pai ce arata:ABS aprins pe bord:sensori defecti sau deplasati,mizerie prinsa sub senzor.Daca dai roata(rotile) jos,gasesti senzorul si il tragi afara cu grija sa nu il rupi,verifici daca roata cu caneluri de sub el este curata,il cureti de pilitura si alte resturi,verifici cablul de legatura,il pui la loc impins pana atinge(misti roata sa auzi,dupa asta il tragi 1/2 mm inapoi,sa nu atinga.In cel mai rau caz este placa de control de pe pompa acolo deja nu te descurci singur.La calculator iti poate aparea care senzor se da defect/deplasat dar este relativ.De obicei,daca nimeresti se stinge si beculetul.
Oct 22, 2013 | 2000 Chrysler Grand Voyager
Buna ziua am si eu un tel nokia X3-02 si nu merge, cind bag o cartela in el imi spune (enter restriction code) ma-m tot uitat pe net si nu ii gasesc un cod de deblocare, tel la-m primit. este adus din...
Bun? ?nseamn? c? telefonul mobil este blocat la re?ea, ave?i posibilitatea s? debloca?i telefonul mobil prin coduri debloca .. mod sigur cea mai buna si de deblocare este de coduri debloca ?i cererea mea personal? este c? nu merg pentru programul de deblocare, deoarece, uneori, software-ul s-ar putea ob?ine corupt ?i poate datele dumneavoastr? vor fi pierdute din cauza c? ?i, de asemenea, dont du-te pentru deblocarea gratuit, deoarece codul generat de circula?ie pot merge gre?it uneori, sa-mi experien?? nepl?cut?, a?a c? am mers pentru deblocarea de codurile din superunlockcodes ?i unlocked.you pot ?ncerca prea dar se vedea ?n acest dac? ?ara dumneavoastr? ?i furnizorul este listat .. deoarece pentru unele servicii sunt disponibile numai coduri .. verifica cu faptul c? ?i ?n cazul ?n care furnizorul de ?ara dumneavoastr? este listat, apoi ob?ine coduri ?i de a debloca telefonul mobil ..
Sep 21, 2011 | NokiaFree Unlock Codes Calculator
Buna calculatorul meu nu citeste cardul de micro sd 4 g cu adaptor szik173@freemail.hu
Salut! Daca cititorul de carduri este un model mai vechi nu iti va vedea carduri micro sd. Incearca cu un cititor extern pe usb mai nou si vezi daca merge.
Mar 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
A ramas cursorul blocat da ii introduc un mouse merge sageata dar daca scot mouse-ul nu mai merge. s-a blocat dintr-o data, era pus pe pauza la un film cand sa luat lumina si sa intrerupt internetul pt ca...
driverul de touchpad a fost corupt. dezinstaleaza-l din Control Panel > Programs si descarca unul nou de pe situl producatorului laptopului tau. cind descarcarea s-a terminat instaleaza-l.
Feb 28, 2011 | Computers & Internet
Nu pot intra pe facebook din cauza ca mi,am uitat parola.*** puteti sa ma ajutati?
Pe pagina de logare este un link "Ti-ai uitat parola?". Il accesezi si urmezi pasii de acolo pentru a-ti recupera parola.
Feb 13, 2011 | Computers & Internet
Salut! Nu stiu de ce nu se mai vede cand scriu la cineva pe messenger si nu se mai vede nici cand scrie cel cu care vorbesc .!!!nu stiti de ce? Multumesc!
Salut, Este un bug destul de des inatalnit la Y! messenger mai ales pe conexiuni wireless.
Exceptand posibilitatea unui virus iti recomand sa inchizi si sa redeschizi Yahoo messenger, pentru a te reconecta la serverul Yahoo.
Feb 01, 2011 | Yahoo Messenger
Salut Am o problema cu id meu de yahoo mail si messenger, nu ma pot conecta la el Imi da o eroare 81003003, folosesc acest id de citiva ani si am nevoie neaparat de contul meu deoarece am date necesare mie...
buna acum vreo doua zile mi s-a blocat contul si nu mai pot folosi adresa de mail si ID de mess
, sori_modovan@yahoo.com la intrebarile nu mai pt raspunde deoarece nu imi amintesc raspunsurile pt ca adresa a fost facuta acum aproximativ 8 ani. va rog frumos sa ma ajutati ca am nevoie de informatiile din adresa. astept raspuns pe adresa moldovansorin17@yahoo.com va multumesc anticipat sorin moldovan
Nov 28, 2010 | Yahoo Mail
Nu recunoaste tastatura si usb
Clar este o problema cu driverele. Cea mai comoda solutie este sa instalezi sistemul de operare din nou si sa descarci driverele cele mai noi direct de pe situl acer.
Jul 13, 2009 | Acer Computers & Internet
*** sa recuperez pozele sterse de pe aparat?
descarca un program free de aici: http://www.snapfiles.com/screenshots/mjmphotorecovery.htm
iti va recupera pozele. bafta. mai multe detalii pe id mess : naebarbat
Oct 17, 2008 | Fuji FinePix A400 Digital Camera
190g ajutor:):)
no mai fi bun cablul de alimentare dela monitor ancearca alt cablu daca nu mere dul la reparat
Oct 05, 2008 | Computers & Internet
Midland 1001Z 40-Channels Base CB Radio Logo
24 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
