Question about Makita Saws
Makita JM27000 Makita table saw stand JM 27000
  • 23 Answers
SOURCE: need owners manual for makita 2703 table saw..
http://www.makita.com/en-us/Assets/images/Products/2703/owners_manuals/
Posted on Nov 28, 2008
danny_murray
  • 55 Answers
SOURCE: preventive maintenance
Here is a link to the owners manual
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=197
Posted on Dec 05, 2008
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
  • 360 Answers
SOURCE: no book.how to square craftsman table saw mod 137 blade to table
Thanks for using Fix Ya
To download the owners manual for your saw, click --->here<---
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 15, 2009
jyackle5
  • 8197 Answers
SOURCE: will the skil 80092 table saw stand accomodate the
Yes it will hold the Bosch 4000 with a little modification.
Posted on Mar 02, 2010
Testimonial: "Do you know what modifications i would have to make ? It would be of great help to know what i'm getting into before i purchase the stand!! Thanks "
Makita LS 1000 miter bed does not turn freely; probably jammed up with saw dust. What is the best approach to cleaning the rotating bed?
PDF]TECHNICAL INFORMATION - Makita
www.makita.nl/images/files/onderdelen/nl/LS1020-TE.pdf MAKITA 255mm(10") Miter saw. Models No. Description. New Tool ... Optional accessories. The main specifications are common with #LS1000. Saw blade:.Missing: bed
Jul 22, 2015 | Makita Saws
Jm27000300 instruction manual
I suspect you may find instructions on this webpage for combined table/stand and saw as pdf download
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?Name=2705X1
I can download the manual from this webpage but Fixya does not allow document attachments.
19.August.2014
Aug 19, 2014 | Makita 2705X1 10" Table Saw with Stand
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
Table saw will not turn on. I have replaced the switch and had electrician check wiring. Any other suggestions?
Look for a fuse on this thing. Also, try plugging into a different outlet that you know works.
Feb 19, 2010 | Makita 2703X1 10'' Table Saw with Stand
The blade is all the way up, and it seems that the crank is somehow locked, or jammed.
This will happen if the crank is force beyond the stop possion and excessive tension is applied to the gear. Just firmly but gently turn the crank back, it will come. Good luck.
Mar 29, 2009 | Makita 2703X1 10'' Table Saw with Stand
Makita table saw switch wiring
i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
Mar 01, 2009 | Makita Saws
How to set fence square to blade
dfowl:
Try this first:
http://www.makita.com/en-us/Assets/images/Products/2703X1/owners_manuals/2703.pdf
Jan 27, 2009 | Dewalt DW744S 10" Portable Table Saw with...
Saws Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
