Question about Clarion DXZ845MC CD Player
Melted flatwire.. ok , on the bottom of my head unit (clarion DXZ845MC) theres two peice's off flat copper wire that were once connected and now are not . i guess becuase there either was a short some where or it got way hot .. i dont know . i want to know i what to do to reconnect these wires . i cant really solder ther because there look like they were a coverd circit .also i checked and there are no blown cap's inside
  • mike cardamone Jun 06, 2007
    this sucks cuz im broke...
SOURCE:
simplemitch
  • 752 Answers
SOURCE: INSTALLING A CLARION MODEL DRX6375 CAR STEREO INTO MY HONDA ACCORD 1995
If you go to your local stereo shop (or even Wal-Mart..) you can get the harness that plugs directly into your cars wiring for about $5-10. It will have the EXACT same wire colors as the harness that came with the Clarion. Just match them up, plug it in and you're good to go!
Posted on Nov 09, 2007
  • 111 Answers
SOURCE: clarion drx9675z head unit connector
Go to pacparts.com
They are authorize parts dist. for Clarion
Posted on Feb 01, 2008
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Posted on Apr 15, 2008
SOURCE: clarion drx9375r
Ask your friend Donald, maybe he could help you....:)
Posted on Sep 30, 2008
style_points
  • 34 Answers
SOURCE: I just install new Clarion BTL370 in the Clarion
A few things to check...
Make sure the receiver is set to "tel sw" or something similar in the menu. From there, you should be able to set the call to the left or right speaker. Make sure you set the headset to the same side.
Another thing to check, make a call and get connected through the headset. Now wait a few seconds and push a button on the phone to power the backlight. If it is wired correctly, you should see the "connected" timer on your phone keep time. If it appears that you are connected, the problem is most likely in the settings.
Also, if nothing else works, make sure that you have the accessory wire(should be red on the BLT370) connected to the right wires. All the other wires will power it on even if this wire is not connected correctly.
Posted on Jul 27, 2009
How many devices can be connected to the head unit at once.
Since you did not specify your device, there is no way we can provide assistance. Please reply with manufacturer, model number, year, etc.
If all else fails, I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
Jun 20, 2015 | Clarion Car Audio & Video
What is the wiring color code to hook-up my Clarion DXZ845MC
I really have no idea.
Recommend contacting a local car audio professional or Clarion customer support directly here:
Mar 07, 2015 | Clarion Car Audio & Video
Clarion XMD3 No Sound
instead of trying to put a new head unit on it i would get a new wiring harness might have some bad connections in that if that doesnt work a new cd player would be the way to go can get a brand new one at abc warehouse for about 75 bucks
Jun 10, 2010 | Clarion XMD3
Clarion DXZ785USB - Connecting Fused Lines
You will definitely need to connect the Yellow Wire Memory Back-Up Lead, since this is the connection from the radio to the battery that stores the time and your presets. If it is not hooked up, you can use the radio, but all your settings will return to default once you turn off the car. The Yellow Wire Bus Power Lead sounds like it would be for powering an auxiliary unit like a Sat Radio or HD Radio add-on. You will not need to connect this unless you have an add-on such as one of these.
Jan 29, 2009 | Clarion DXZ375MP CD Player
Message of an Error
error 6 means that a disc is loaded upside down.
eject the disk and reload it properly
if that isnt working, your CD player is mal-functioning and you should consult Clarion for help
J
Mar 12, 2008 | Clarion DXZ845MC CD Player
Kenwood Head Unit Making a Loud Popping Noise at the Start and Finish of each track
my mate had the same problem with his stereo in his case it was power related if u are usin crimp connections or any other form of connection to the speakers or the subs that is not a soldered joint it could be that we had to re wire his system with soldered joints and it worked ok. but other than that it could also be ur wires themselves with power cutting out cos the poppin sounds to me like the power cuttin out or in. other than that i really cant think of anything hopefully that helps
Jun 11, 2007 | Kenwood KDC-MP228 CD Player
Clarion DXZ845MC CD Player Logo
174 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
