On windows install winsetup.dll error
The chkdsk says disk is fine however i cant not load any windows OS, Ive tried xp, 7 and vista recovery and new install. the same error message comes up - winsetup.dll corrupt or missing. I know its the hard drive and I'd like to repair it.
  • 2,878 Answers
Even with a complete fdisk, thorough format, and chkdsk /f/r ? If so, there is a bad sector(s). Don't think they are repairable.
Posted on Nov 29, 2012
SOURCE: ACER 4720Z
It's very easy. You can switch SATA mode from AHCI to IDE (in Bios) and install XP, or leave AHCI mode, with 'nLite' integrate AHCI drivers into XP installatin files, burn and install... Drivers are not problem, just search in google, even ePower tools are working.
Posted on May 14, 2008
  • 41 Answers
SOURCE: downgrading from windows 7 beta to windows vista
Did you happen to make a recovery point? Vista is pretty good about this. Restart your system and push f8 until you get to the recovery and troubleshooting. Then just use recovery console and restore it to a previous point. If you cant do this you might need to do a fresh install of vista.
Posted on Apr 09, 2009
buffalonyman
  • 1865 Answers
SOURCE: want to install windows xp as a second OS on a
You have to partition your drive in order to install another operating system, or install another drive
Posted on Jul 09, 2009
KingDWS
  • 1606 Answers
SOURCE: One day after a Microsoft automatic update to my
Sounds like you have two problems going on. I would go into the bios and set the drive specs instead of leaving them on automatic to see if that stops the bios error. That can also be from a power problem or the drive is failing which would explain the windows error as well.
Posted on Oct 24, 2009
  • 969 Answers
SOURCE: Alright this may sound big
which hard drive have u selected 2 boot in ur BIOS? Pioneer BIOS? Hit F9 during reboot costantly until u hear a ding.
Posted on Dec 23, 2010
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Jan 11, 2016 | Dell Inspiron Computers & Internet
I have Vista OS on my laptop & have never been able to get automatic updates to work. I have had nothing but problems with this OS & want to instal Win 7 but I am told I can't do that until I see...
Don't worry about "compatibility" issues. You can pretty much force Win 7 onto just about any laptop.
What you need to do is backup your files (that is if you have any you want saved)
You need to do a CLEAN install, not the UPGRADE when you boot from the Windows 7 cd.
Delete ALL of the partitions...then hit NEXT.
When it's done installing, run the updates and if you're missing any drivers after the updates post back the model of your laptop / desktop and we'll help you patch the missing ones.
Best of luck!
Jan 02, 2011 | Microsoft Computers & Internet
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
OS will not boot up. unable to start in any mode and also unable to do chkdsk. doing an OS will not boot test, results in sata error uncorrectable data or is read only
My best guess is that your hard drive has failed or is failing. Replace it. Boot to your Windows CD/DVD and install windows. Then add your old drive as a second disk and, if you are lucky, you can copy your data from it before it fails completely.
Good luck. I hope this helps.
Nov 13, 2010 | Computers & Internet
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Windows is resuming message
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
You can try this first before the XP repair :
Chkdsk
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
Nov 04, 2009 | Sony VAIO PCG-TR3AP1 Notebook
Missing dll file.system32\hal.dll
For that first you have to fix error on harddisk.
Boot computer with recovery disk then choose recovery console mode.
Then type in prompt "chkdsk /r"
then press "y"
then it fix error on harddisk then install windows.
Let me know if you need more assistance.
Thanks.
Oct 04, 2009 | Microsoft Windows XP Professional
Please help
i *** notknow what OS u r using but if it is WIN XP u have to use automated recovery or use ur recovery disc to re-load hal.dll
Jul 18, 2009 | Acer Aspire One PC Notebook
Downgrading from windows 7 beta to windows vista
Apr 08, 2009 | Microsoft Windows Vista Ultimate Edition
Loading problem
try to run again the system restore cd, what OS you are using? is it old or new acer laptop?
if you have new laptop with Vista OS it should be ok.
if you have new laptop design for vista but rather installed XP maybe you will encounter difficulties loading drivers if you dont have xp driver cd (acer provided)
if you have old laptop with XP OS it should be ok.
if you have old laptop w/ lower memory and trying to install Vista it will not work or you will incounter difficulties
Mar 16, 2008 | Computers & Internet
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
