Averatec 3120V reinstall of winXP pro sp2
Hi I am trying to do a fresh load of xp pro sp2. I get part into the install and it is asking for files which I believe to not reside on the standard Win XP 2 cd. I'm looking to get drivers, etc that apply to this pc.also a current bios update as well.I don't want to use driver detective or any pay site I just want to get what I need from the manufacturer .
Thanks
Lou
  • Anonymous Jan 11, 2009
    In respone to Ziraffa;
    The issue is not the ntldr but when I try to use an XP Pro cd to do a fresh load there are a whole host of files missing . I have used this image before and have know good copies so its not a bad cd. I believe that I will need a restore cd for this machine Averatec 3120V .Any body know where to purchase a copy.
  • chris grams
    chris grams May 11, 2010
    Is it asking for ntldr?
  • 4,338 Answers
Here is TriGem's site (they make Averatec laptop).
I see the 3200, 3300 series among other models, but I did not see the 3100 series laptop. Drivers from the 3200 may work.
For USA:
http://www.trigem.com/us/support/drivers.asp
Global:
http://www.trigem.com/support/drivers.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 10, 2009
I bought a used ibm r40, changed the hard dsrive and tryed to load xp pro. after loading the system files the computer wants to reboot to finalise. After this it goes right back to fresh install start.
When you say you tried to load XP Pro, did the hard drive already have XP installed or are you installing it fresh from a CD? If you are installing it fresh from the CD and it is asking you to reboot, it seems as if you are letting it try to boot again from the CD. When it reboots and says "Press any key to boot from CD..." don't press anything, just let it boot. It should finalize the installation there!
Hope that helps!
May 23, 2011 | IBM ThinkPad R40 2722 Notebook
I has delete file on memory's intermec cn3, How to recovery file ?
REPAIR YOUR OPERATING SYSTEM AS FOLLOWS
Download the operating system from this link: http://www.microsoft.com/downloads/en/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
or
if you have it, install it using the procedure below:Boot From the Windows XP CD
  • You must boot from your XP . Please make sure it is the same version of Windows that is currently installed on your computer (ex. XP Home cannot repair XP Professional). Place the CD in your CDROM and start your computer. Newer versions will work as well (ie. Windows XP Pro SP2 CD will work on an older WinXP Pro SP1 installation)
    you will be asked to press any key to boot from CD, so do just that.
    Step 3: System repair steps
  • A blue screen will appear and will begin loading XP setup from the CD.
    simply let the CD load without pressing F6.
    Once completed, you will be confronted with "Windows Setup". You will be asked to setup up Windows, or repair Windows with the recovery console. Choose the FIRST option, NOT recovery console.
Choose F8 to continue.
  • Next, Windows Setup will find existing Windows XP installations. You will be asked to repair an existing XP installation or install a fresh copy of Windows XP.
    If no installations are found, then you will not be given the option to repair. This may happen if the data or partition on your drive is too corrupted.
That should be it. Windows XP will appear to be installing itself for the first time, but it will retain all of your data and settings. Just follow the prompts
  • If this solution helped Never go to drive C: again. Vote for this solution and rate it
Apr 20, 2011 | Computers & Internet
Haha! I deleted folders inside the Local Disk C:\Program files then after that the computer would always ask to restart it, every time I try starting it. Huhu Help, and these folders are not inside the...
or
Apr 18, 2011 | Computers & Internet
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Averatec 3120V - AC adapter light blinking, no charging
get another ac adapter or check if the power dc jack is loose.
Apr 01, 2010 | Averatec 3120V Notebook
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
Error code
Apparently the XP Pro CD you are using is pre-SP2, thus causing the error. With XP RTM and SP1, you need to supply the proper SATA drivers for the chipset on the motherboard since there is no built-in support for SATA drives. You can download the drivers from http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=2214&areaid=2&LanID=0
During the XP setup you will need to press F6 to install these driver before attempting to copy the XP files to the drive. Or you could make a custom XP CD using the directions at http://maxeasyguide.blogspot.com/2008/04/preparations-for-winxp-installation-cd.html that has these SATA drivers already slipstreamed into the installation procedure.
Or if you know someone who has the WinXP Pro SP2 CD, you could borrow that for the install.
Apr 07, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Tis about REALTEK blahblah...i cannot see the volume tray icon
As you said you have formatted Drive C:, and installed XP SP3 and back again XP SP2.
Why don't you try formating the whole drive and reinstalling fresh Win XP SP2 and always choose NTFS partition only because all the features are supported in this partition.
Mar 18, 2009 | Asrock ALiveNF7G-HD720P M/board, nVidia...
BIG BOOT PROBLEM!!!!
You should have erased the system root directory,( the Windows XP installed drive). the boot sector still has the winxp boot information, but does not finds any file on the drive, were they are supposed to be.
You have to Install a fresh copy of winxp, with the winxp boot cd.
Jan 09, 2008 | Compaq Presario 5000 PC Desktop
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
