Question about Canon CanoScan 8000F Flatbed Scanner
CanoScan 6000F Flatbed scanner light is scanning pink. How do I fix this?
  • 111 Answers
SOURCE: Canon CanoScan 5000F Flatbed.
Make sure the scanner is unlocked. Lock switch is either on the bottom, or under the scanner lid near the hinges.
Posted on May 09, 2008
  • 5 Answers
SOURCE: TWAIN ERROR AND CANOSCAN LIDE 20 SCANNER PROBLEMS
Well I had a code 15 error with mine LIDE 20. Apparently the scanner needs a certain amount of power to run off the USB port. So I changed the USB port and problem fixed
Posted on Jul 16, 2008
zohail
  • 1223 Answers
SOURCE: Lines on scanned documents
pls update the driver
http://canon.driversdown.com/Canon-driver-list/s_421_1.shtml
pls clean the scan glass , if it helps otherwise
ur CCD engine inside the scanner is weak now after use there is no point in getting it replaced as it is not worth pls find a new scanner
HP are excellent and MUSTEK are good and economical
pls rate me if i diagnosed ur fault
Posted on Mar 09, 2009
gewiz
  • 1263 Answers
SOURCE: How do I scan multiple pages into the same file?
http://www.driverfiles.net/Scanners/Acer/SCANPRISA-640P/download/page,sh,19322,359,11,.html
Posted on Jun 13, 2009
  • 18 Answers
SOURCE: CanoScan LiDE 30 Flatbed Scanner: When I click the scan button it says, "Cannot find...
Make sure the USB cable is properly connected at both ends. Close the Canoscan software and then reopen it and try again.
Posted on May 20, 2010
May 18, 2010 | Canon CanoScan LiDE 30 Flatbed Scanner
My scanner can't scan
You should re-install driver for the scanner
Dec 15, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
After preview with correct colour, print comes up pale colours.
Have you confirmed that the scan you are trying to print is good?
Dec 13, 2008 | Canon CanoScan N640P Flatbed Scanner
Re : CanoScan N640P/Lexmark Printing Problem.
There could be a setting in your scanner drivers to fix that. It would be under background settings.
The other thing you can do is preview the document first and select the area you want to scan. Then press the scan button again. That way the black background that isn't needed will not print.
Jul 29, 2008 | Canon CanoScan N640P Flatbed Scanner
Out of Focus Scans
You have some limited color adjustment settings in ScanGear that you can play around with. I would recommend recalibrating the scanner. This is done in ScanGear Advanced mode under Image Settings.
May 28, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Apr 23, 2008 | Canon CanoScan 5000F Flatbed Scanner
Help
You'll have to do that in the software that handles the image after scanning. Do you start scanning from your computer, or direcly on the scanner? While executing the scan from the computer, you can select the save-path there. While executing directly on the scanner you need to to go to the settings of your scanner, i think.
Mar 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Redish/Pinks color to scans.
You need to reset your scanner's color management settings to default..
Which utilty software r u using?Arcsoft Photostudio?If yes go to Edit ->preferences
Set RGB settings to the same level(adjust the slider next to red)
If it doesnt work or u r not using arcsoft..post back..
Nov 04, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan 8000F Flatbed Scanner Logo
83 people viewed this question
old marine
old marine
