Question about LG E2250V-PN 21"LCD Monitor
Lg flatron E2250v blinking lights - LG E2250V-PN 21"LCD Monitor
  • 749 Answers
SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Posted on Nov 27, 2007
ginko
  • 19396 Answers
SOURCE: monitor light blinking
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 22, 2009
SOURCE: No picture lg flatron w2234s blinking blue light
Hi My screen developed exactly the same problem. It appears to be a hardwear problem associated with the screen it's self. continuity test is ok on the lead so I took it back to the shop under warranty and hey presto, the replacement works. I don't know what the problem is but there are a number of other folks on another thread with the same problem and their entries are dated May 09 too.  Dave
Posted on May 29, 2009
  • 16 Answers
SOURCE: my lg 17inch CRT flatron
Did you check to make sure the PC is sending a video signal? Try another screen to confirm if possible...
Posted on Oct 22, 2010
SOURCE: My LG Flatron e2250v 22'
solution of this problem changing of switches
Posted on Jan 31, 2011
Disassembly lg e2250v
To disassemble your TV you need a screw driver to unscrew the cover and other parts that you need to take off..
For proper instruction go and download manual on www.retrevo.com
Jan 16, 2012 | LG E2250V-PN 21"LCD Monitor
My LG E2250V-PN turns on and my Macbook goes to a blue screen, indicating that it is picking up a signal, but then nothing happens. My Mac screen never shows on my LG. Also, even if i try to press the menu...
Hi sophie,
I see you want to extend you monito to an LG external monitor.
Have you tried selecting the input PC or the input that is for the cable that you are using for the Video.
If you are using HDMI select the Input HDMI on your LG if you are using DVI then you should select the input DVI to be able to get the signal from the Laptop come out of your LG.
I hope this helps.
Have a nice day,
mvincentc
Jun 25, 2011 | LG E2250V-PN 21"LCD Monitor
NO DISPLAY AND THE POWER LIGHT IS JUST BLINKING ON MY LG FLATRON T713SH MONITOR... HOW CAN I FIX IT? ANY GUIDE FOR TROUBLESHOOTING THIS KIND OF PROBLEM?
u better to check the VGA connection to the PC and power on the monitor.power on located at the booton part of the monitor
Oct 03, 2010 | LG Flatron Ez T710BH 17" CRT Monitor
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
THE POWER LED (GREEN) IS BLINKING CONTINUOUSLY
LG 700E monitor's power LED blinking continueously and there is no display solutin ........
May 30, 2009 | LG Flatron F700B 17" CRT Monitor
Blinking Screen?
it is monitor problem,it should be EHT problem
Feb 29, 2008 | LG Flatron L1750S 17" LCD Monitor
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
LG E2250V-PN 21"LCD Monitor Logo
41 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
