Question about Toys
How & where do I oil a Lionel 6026W tender - Toys
2 Suggested Answers
  • 2841 Answers
SOURCE: Lionel 618 tender. Whistle
The symptom you describe is in part due to the way Lionel designed their
whistles controls. The old style copper oxide rectifiers Lionel used (to
produce the low DC voltage to activate the whistle control relay in the
tenders) will overheat if they carry the full current drawn by the train for
an extended period. Lionel whistle switches are arranged to deliver the
full DC as the switch is partly depressed (to pick up the control relay in
the tender), and then at full travel to add a resistor shunt around the
rectifier to reduce the current flowing through it. This slightly lowers
the DC voltage, but should still be enough to hold the relay closed.
The fact that the whistle blows means your copper oxide rectifier
is probably ok. One possible problem is a dirty or bent contact on the
whistle control so that it is now properly adding the shunt resistance at
full travel, or may be interrupting the circuit through the rectifier. The
other likely problem is the whistle control relays in the tenders. These
are very sensitive devices that need to have clean contacts and proper
adjustment to work. Take the top off the tender and connect it directly to the transformer (by setting the tender on a separately
powered section of track, or by using test leads, but be sure the tender is
in the normal level position). Watch the operation of the "flapper" at the
bottom of the relay, and the alignment of the contact. I clean the contacts
by using a pencil eraser or if they are really bad by gentle using one of my wife's fingernail emery boards. There are two 1/16" square bent tabs at the pivot end of the "flapper" - they need to be
carefully adjusted so the moving end does not bind in its guide. You'll find more help on the Lionel Service manual pages at the Olsen's Toy
Train Parts site. Start with:
http://pictures.olsenstoy.com/searchcd31.htm?itm=708
but there are several other helpful sheets in the "Whistles" index as well.
Good luck
Posted on Aug 13, 2011
Coupler will not stay closed on tender this was new out of the box
Contact Lionel Customer Service for a repair/replacement or take the tender to a Lionel Service station.
Jan 27, 2016 | Crafts & Hobbies
Lionel 2466WX Tender -- HOW do I get it to WORK? (Assuming that it does work)?
Good work, Dan! Fixing trains can be as much fun as running them.
Apr 22, 2014 | Crafts & Hobbies
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
Dec 03, 2012 | Lionel 11000 Holiday Tradition Express...
Instruction manual
Search the Internet, you may find a PDF file containing the manual. If all else fails, contact Lionel and request a manual.
Dec 08, 2011 | Lionel 'o/o27' 1645 4-4-2 Pennsylvania...
Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Nov 27, 2011 | Lionel 11000 Holiday Tradition Express...
Toys Logo
134 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
