Samsung HP-R4272 42 in. Plasma HDTV Logo
Posted on Jan 10, 2009
Tv does not turn on, no picture, no tv, after just one day of use
Called samsung, they said probably power supply, TV should be sent back. I agree. Is this an easy fix, is it expensive? The reason I ask is that it was purchased bestbuy online. I am still waiting, since xmas day, for someone from the online co. to call me. I tried bringing back to the store and they do not except online purchased TV's. Awful policy. They have been giving me a really hard time, never again, anyway it may be easier for me to just have it fixed. Trying to gather all my options.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
195
Points
0
You heve a fuse bad i power supply
1helpful
Can you help me troubleshoot my TV? It has audio but no picture.
Use a voltmeter to confirm all the voltages are present when the TV is powered on. If they are all correct then replace the led driver.
1helpful
3answers
How do I fix my Samsung 40 LED TV that has sound but no picture?
Here is what to check when your TV is turned on, power light is ON, but no picture is seen or sound is heard:
1 - Be sure the component you are using (Xbox, Cable, SAT, ROKU) is turned ON.
2 - Check to be sure all cable and cords are securely connected to the TV inputs and component outputs.
3 - Make sure you are on the correct input as some TV's will show a black screen if there is nothing connected to that input.
4 - Unplug the input you are trying to use from the TV (such as an HDMI Cable) and plug it back in.
5 - Check for signs of damage on all cords and cables from the TV to all components.
6 - Make sure the TV is not in ENERGY SAVE MODE, press the button on the remote control to go back to normal mode.
7 - Unplug the TV for 10 minutes to see if there was a temporary one time issue with the TV.
8 - Disconnect the TV from power for 2 minutes, then when plugging it back in PRESS AND HOLD THE POWER BUTTON ON THE TV FOR 10 to 20 SECONDS to try and force the TV to reset.
9 - If after checking all these different issues, you may have a Faulty Power Supply Board, A Bad Capacitor on the Power Supply Board, Loose Wire Harness, or Loose Ribbon Connector in the TV itself.
10 - Most likely when a TV has the power light ON but NO PICTURE and NO SOUND, it is the Power Supply Board that has failed.
BTW, here are solutions for you to play iTunes movies on Samsung smart TV
4answers
Samsung PS42B430 42" Plasma tv. LED flashes and
The tv power supply board have more dead components parts,u just don't have the skills an the know how to trouble shoot find out more dead components parts that all.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
7helpful
3answers
Samsung tv wont turn on stand by button just keeps clicking
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem
Not getting a picture from a Samsung 46" LCD TV
check if the back lamps are still on when you lose image, all you have to do is get close to the screen and make is totally black and if is not that means you have a back light working, but if the back light is gone you may have a defective panel.
talked to samsung TA about the same problem I had and the recommend to replace the power supply first to confirm a defective panel because a panel is quite expensive
2answers
Samsung 32'' LCD (LA32R81B) is as good as dead
I would venture to say it is the power supply first. Capacitors in LCD power supply's frequently go bad after a year or two. LCD displays very seldom go bad and I have not seen one kill a set completely.
Olevia 747 won't come on
I had the same problem with a 437. It just shut off one day and I could never turn it back on again. I called Syntax Brillian and they told me the mother board was probably shot. They sent me a new TV and took the damaged one back.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
