Question about Gateway E-4200 Notebook
Gateway E-4200, Pentium III, Win XP, Nothing Showing On Monitor
I have an older model Gateway E-4200, Pentium III. The computer was left out in cold weather for a few weeks but was brought in on Christmas day 2008. It was then left alone to "warm up" and "dry out." I turned it on today, but nothing came across the monitor; however, three loud beeps came from the computer, and then it sounded as if the computer normally booted up. I could not see if the computer was okay because nothing came across the computer screen. The sound card was removed, and I thought that might be part of the problem, but I don't think it is. The cables are all plugged in, (monitor, computer, etc.) and the monitor was hooked up properly into the video slot. What could the problem be? Thanks!
    President:
  • 1,179 Answers
The beeps are usually an error code meaning either the RAM or video card has went bad or are not properly seated. Leaving it out as you did could have caused the parts to come unseated when you moved the unit. Try reseating the RAM & video card and then retry booting. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 10, 2009
I installed xp proffessional on my system but i could not get sound driver and when i started play to song then system informed me that there is no sound driver.
Hello ,
I think *********** will be 810 or 815 , but try to check *********** board carefully there will be a audio chip top left corner .(AD/RALTEK/ECS/) .
Download the driver,from that company website.I am giving an example for download there driver .
Think your name of the motherboards Intel
So you will do those steep.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22865%22
Type model no on the searchoption Choice the product (e.g.chipsets)> Desktop chipsets/laptop board> Choice chip no(e.g.865/945)> Selects your OS from leftside (e.g. sp/vista/win 7)> Click on driver > Now look bottom the page, anddownload one after one. Hope it will help you.
Dec 25, 2010 | Intel Pentium 3 , 450 MHz Pentium III...
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
I found following wording on my motherboard: CL-2 SU 94V-0 E241819 What are they telling us? Where can I get the manual and drivers. It seems many drivers are missing when I installed the XP,...
Theyare telling you that your computer takes PC-100 memory at a clock speed of 222Hz. This is memory for older, slower, Pentium III computers. It wiil run Windows Xp Pro on a pentium III at a fairly good speed if you install at least 512MB and have a hard drive with 30GB of disk space. This memory shipped with the pentium III that usually had a HD of 10GB or less in computers made around 2001-2002.
Apr 20, 2009 | Computers & Internet
PC Will Not Boot
hi there
i do agree with you about the ribbon cables please make verry sure that they are connected right ie set as master or slave also make sure that the ribbon is tight and then make sure that you boot into bios and see if the computer can recognize the drive and see if it is set to master or slave and see if there are any jumpers on the hard drive that match with what bios is telling you cause if the bios is set to master and you have the jumper set to slave it will not work
Mar 05, 2009 | Gateway Computers & Internet
New graphics card
Intel Pentium® III, AMD™ Duron or Athlon™ class processor or higher
128MB system RAM
A 300W system power supply
An AGP 2.0 (or higher) compliant motherboard
50MB of available hard disk space
CD-ROM or DVD-ROM drive
Microsoft® Windows® 98, ME, 2000, XP, or Windows®
VGA or DVI-I compatible monitor
This is what you need for graphic card to work!!!
Its very good card!!!
Jan 22, 2008 | Computers & Internet
Samsung monitor performance
Just spoke with ya in chat... ya left a little too soon :-)
You should be able to upgrade that processor to around 1ghz (1000mhz). That will double your cpu speed.
And shop around online for some PC-133 SDRAM for your model of pc. Get that thing up to at least 512mb of system memory and you will probably be alot happier with it's performance! If all you generally do is email and surf the net, no need to drop the bucks on a new machine if your looking for just a little more speed. Unless your wanting something newer anyway, then go for it. But you should be able to upgrade that one yourself for easily under $100 if you shop the parts online.
Oct 31, 2007 | Samsung SyncMaster 713BM 17" LCD Monitor
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Nov 04, 2006 | Gateway Pentium III , 600 MHz (1515824)...
Computers & Internet Logo
411 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
