Question about Heavy Duty Westinghouse 3-Outlet Outdoor Digital Photocell Timer
Replacing the battery in the 28011 timer
When trying to program the unit, the display doesn't show on the screen. Is this becase of a low or bad battery? What is the battery number and how do you replace it?
3 Suggested Answers
BillB-SA
  • 2761 Answers
SOURCE: Need instruction sheet for a Westinghouse 6-plug
You can download/print your manual here:
http://www.thencc.com/westinghouse/LS/Instruction/28011_Manual_2007.pdf
Posted on Dec 09, 2009
jyackle5
  • 8197 Answers
SOURCE: setting instructions for a model 28011 timer
You can get the manual on the link below.
http://www.thencc.com/LS/Instruction/28011_Manual_2007.pdf
Good Luck
Posted on Dec 03, 2010
Utilitech wall timer
Utilitec timers do not have replaceable batteries.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
http://waterheatertimer.org/ST01C-program.html
Add a comment
Jul 18, 2013 | Hardware & Accessories
Sunset sunrise doesn't seem to work anymore
Timer is not identified.
If digital timer does not function as before, try resetting timer and then re-program.
If timer has battery, then change battery and reset timer.
If reset does not restore functionality, then timer has gone bad. Most in-wall timers have 1 year limited warranty.
Below are common 7-day timers, but there are many different brands:
You posted under Woods 7-day timer: except Woods timer does not astronomic dawn dusk function. Woods 7-day is same as Tork 7-day and GE 7-day, and they do not have astronomic function.
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Reset button is small round button.
Push in reset with toothpick or paper clip.
Then reprogram timer.
If you have Intermatic ST01C or EJ500 battery operated timer: Replace battery, then to reset timer: push-and-hold ON_OFF button, and then push reset button. Keep holding on-off button until display changes. Release on-off button and display will flash 12:00. Then reprogram timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
If you have Utilitec astronomic timer, then press reset button and reprogram:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Aug 05, 2011 | Woods InWall 7 Day Digital Programmable...
I replaced my batteries and it still read Lowbat. Is the unit gone bad?
Unit might be bad.
EJ500 has 1 year limited warranty.
Try resetting timer: hold down on-off button and push-and-release reset button.
Keep holding on-off button until display screen changes.
This action will reset timer, and if 12:00 is flashing then timer will probably accept programming.
Reprogram timer.
http://waterheatertimer.org/Flipdown.html
Jun 16, 2011 | Intermatic Inc. EJ500C Digital Wall Switch...
Dosnt work
If display is scrambled, reset timer: Push reset button while holding down enter button.
If display doesn't show, check AAA batteries.
If timer still doesn't work, then Contact Intermatic.
8000 series comes with 1 year limited warranty
https://parts.intermatic.com/
Intermatic does not show replacement memory board for ET8000 series
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 29, 2011 | Intermatic ET8215C- 7-Day Electronic...
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a new Nordik digital indoor timer TD133B. It has never displayed information on it's screen. The instruction manual indicates plugging it in for an hour to charge the battery. I did this but still...
Most plug-in timers have rechargeable battery that is not replaceable.
Instructions say: Plug in timer for hour and then unplug it to set programs.
Intermatic makes a couple plug-in outdoor timers with replaceable batteries that load from back of timer, but otherwise batteries are rechargeable.
If battery will not charge, then display doesn't show, and that signals the timer is no good.
Take timer back if you can, and exchange for another.
I was looking at timers in Walmart and Target yesterday (since my specialty, and interest is timers).
New plug-in timers are inexpensive.
Lowes and Home Depot also carry inexpensive plug-in timers.
Be sure to save timer instructions because generally, store-bought timer brands don't show manuals on-line. Except GE brand timers from Home Depot.
Add a comment if you need more help.
Nov 25, 2010 | Hardware & Accessories
Heavy Duty Westinghouse 3-Outlet Outdoor  Digital Photocell Timer Logo
70 people viewed this question
Top Heavy Duty Hardware & Accessories Experts
jeff5may32
ray gallant
Gene Haynes
Are you a Heavy Duty Hardware and Accessory Expert? Answer questions, earn points and help others
