Question about HEWLETT-PACKARD Computers & Internet
HP G62 BIOS rest jumper location
Where is the jumper to reset the BIOS?
acdr
  • 1913 Answers
SOURCE: reset bios password
u can reset your bios 2 ways.
(1) pull away your cmos cell for 15 minutes from laptop mother bord.
(2) u can find jumper nearly cmos cell or in corner of circuit bord.set it in 1-2 position thenpower up the lsatop then again set in 2-3 it isd its original position.
Posted on Jan 03, 2009
  • 43 Answers
SOURCE: how to bios reset jumper location dell c400
try to remove the cover of your laptop. Then remove the motherboard battery for about 10 min. Put it again and bios should be restarted.
Posted on Mar 20, 2009
  • 74 Answers
Most laptops do not have one and clearing the cmos will not help.
Contact HP, they have a master password that can get you in. You may have to fax them proof of ownership to get them to help. I had to do this on a laptop.
Hope this helps
Posted on Apr 30, 2009
  • 3940 Answers
SOURCE: where is the BIOS Password Clear/Reset jumper
There is no Jumper on a Dell Vostro 1000 to clear the password. You will have to contact Dell Technical Support, Complete a ownership validation to confirm you are an authorized user of the system, then they can provide you with a Master Password to clear the password
800-624-9896 in USA
Posted on Jul 11, 2009
  • 74 Answers
SOURCE: Can anyone help me on how to reset the Bios
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Oct 30, 2009
Tip
How to reset or remove BIOS password
There are four common categories of solutions to remove or reset a BIOS password and here are the details on how to go about resetting your BIOS password.<br /> <br /><b>Manufacturer Backdoor BIOS Password</b><br /><br />Most of the BIOS makers have set a backdoor password on the older computer models. That is the master password for BIOS. To reset BIOS passwords first you need to check the manufacturer of your computer's BIOS. Most computers have BIOS include AMI, IBM, Award, and Phoenix. These are the most common BIOS. You can unlock your locked BIOS using this master password. It works, no matter what the user sets the password to. Many popular computer and laptop manufacturers such as HP and DELL lock the BIOS because they want to protect their machine's most sensitive areas (those areas which have warranty) from their customers. These passwords are usually used by computer technicians for testing and repairing. <br /><br /><b>Reset the jumper that holds the password<br /></b><br />Open the computer and locate on the motherboard the BIOS password jumper. The jumper is usually jumper 1 and often labeled as PSWD, PWD, CLRPWD, CLEAR, JCMOS1, CLR, CLEAR CMOS, PASSWD, or PASSWORD. Normally you would have 3 pins and to reset the password you just need to put the jumper on the 2 and 3 pins leaving pin 1 empty. After you move the jumper, turn the computer on to clear the password, then once password removed turn it off and put the jumper back to its original position.<br /><br /><b>Removing the CMOS Battery to reset the BIOS to default</b><br /><br />Switch off your computer, and open up the case. You'll see a circular metallic silver item on motherboard. This is called CMOS Battery. Remove it carefully, and leave it out for about 2 minutes. This act will remove the CMOS memory which contains BIOS password. Set the CMOS battery back and switch on the computer. Restore the CMOS configuration as default. Your BIOS password has been cleared now. <br /><br /><b>Using third party software utility to reset BIOS password</b><br /><br />To reset BIOS you can use third party software like Kill CMOS which wipes out CMOS, or CmosPwd which is a BIOS utility. Hiren's Boot CD has a few programs including the above two that will help you to reset the password. Here is a link to Hirens Boot CD website <a href="http://www.hirensbootcd.org/">http://www.hirensbootcd.org/</a>. To download the latest version, click on the Download link on the left side and go to the last page. You will need a CD writer to put the content on a blank CD.
on Dec 12, 2010 | Computers & Internet
How to remove a BIOS password from a desk top
This is both trickier and easier than you might think.
  1. Shut down PC, disconnect power, and open case.
  2. Look for two pins sticking up off the motherboard that say: "RESET CMOS" or "CMOS PASS" or "BIOS PASS" or "BIOS RESET" or some combination.
  3. There should be a plastic "jumper" that is attached to ONE of the pins on the CMOS jumper (step two).
  4. Carefully remove the "jumper" by pulling straight up on it.
  5. Replace the jumper so that both pins are inserted into it.
  6. Connect Power and Power On your PC
  7. (it may beep loudly and shut off or it may startup like normal, allowing you to get into your BIOS)
  8. Shut down PC, remove power
  9. return the "jumper" (step two) so that only one pin is connected like you found it.
  10. Power on your PC and you should be good to go.
NOTE: If you don't have a jumper on your motherboard, you will need to find one. Often, a CD-ROM drive or old IDE hard drive will have a jumper on it. If you find a jumper on an old device that is not connected and not running, you can use it so long as you remember to return it to it's original position. Failing to return a "borrowed" jumper from an external device could make it unusable in the future.
Also, never use a jumper from elsewhere on your motherboard. These jumpers can be critical to the operation of your PC and "borrowing" one could render your PC useless and may not ever help you to reset the BIOS password.
NOTE: When you reset the BIOS password in this manner, all of your custom BIOS settings will be reset. Any hardware that you had to configure manually through your BIOS may not work. Overclocking and other features may be disabled by default. This should not be done without proper consideration.
Hope this helps,
Jase
Feb 26, 2014 | Computers & Internet
How to disable the power on password on a hp g62-222us
Usually password is wiped when you remove laptop battery as well as the CMOS battery. This works because this basically just resets the BIOS to default. I would not recommend this if you are not tech savy because you will need to remove a few parts to get to it.
Nov 13, 2013 | HEWLETT-PACKARD HP Pavilion G62-222US...
I need to reset the bios on a HP G62-435DX
Hi.
The HP G62 does not have jumpers on the motherboard to short the CMOS/BIOS to reset it, all you can do is turn the laptop upside down and then remove battery and the memory & wifi cover, under that cover you will see a black, round penny shaped item with red wires coming from it. Follow the wires and unplug it. That is the CMOS/BIOS or RTC battery, leave both the main battery and the CMOS battery out for at least 10 minutes. Below is a picture for you to refer to.
Regards.
Dec 12, 2012 | HEWLETT-PACKARD HP G62-435DX Laptop
Jumper settings to reset BIOS on Motherboard Tyan S2925
JP5 Jumper is the reset jumper. Look at this Pdf:
ftp://ftp.tyan.com/quickref/q_s2925_100.pdf
Jun 30, 2012 | Tyan TOMCAT N3400B S2925 S2925G2NR NFORCE...
Cq56 reset bios password
You will have to remove the power cord, remove the batteryand remove the CMOS Battery that is located on the motherboard. On mostcomputers you will have to take the laptop apart to get to the cmosbattery. On some systems it looks like a silver nickel that you will needa small flat head screw driver to pop it out. On other systems it will beinside a vinyl covering and has a cable that plugs into the motherboard. Once you remove the CMOS Battery, let it sit for an hour or two then put itback in and put the laptop back together. Boot the machine and you'llprobably have to go into the Bios or System Setup because the system will haveforgotten the date, time and password.If the password is not reset then you might have to go and remove a Pin from the password jumper on the motherboard. I would consult the user manual and see how to do it.
Apr 28, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
How do i locate the hp probook 4520s BIOS password jumper on the motherboard
4520s.
you failed because of one reason, you asked on fixya not HP'
why ask here, there are no HP(few) folks here, they are all over at HP, real forum.?
bios resets are tricky,
the new rules changed with UEFI BIOS and or TPM chips added.
back in 2007 the mobo had reset jumper, (mine desktop does)
but not my 2008 elitebook laptop, due to the TPM rules.
first the link to your books
https://support.hp.com/us-en/product/HP-ProBook-4520s-Notebook-PC/4145198
those cover most issues, you will have. all by HP direct,
page 126 here is not too clear;.
the answer is here
your PC is fully locked now, there is no way to reset it .
without HP direct intervention (fixya can never ever do that)
the send you a special binary flash file that only works on YOUR PC (a fact and is by DESIGN)
https://h30434.www3.hp.com/t5/Business-Notebooks/Probook-4545s-Bios-Password-reset/m-p/6350164#M147169
never use a BIOS password, unless you write it down and hide the paper in a book you know, where it is. (got books?) i know books are now (dead technology but)>?
if you guess and start flashing BIOS, you will BRICK THIS PC.
Oct 20, 2017 | HEWLETT-PACKARD ProBook 4520s
How to reset or clear a system bios password
The general categories of solutions to reset a BIOS password are:
  • Using a Backdoor BIOS Password
  • Resetting the BIOS Password using Software
  • Resetting the BIOS Password using Hardware
  • Vendor Specific Solutions for resetting the BIOS Password
  • or with a simple one is taking out the cmos battery then place it back 5-10 minutes after..so use the simple one if you don't have the other mentioned above..
  • Goodluck!!!!
Feb 20, 2011 | Toshiba Satellite M35X-S161 Notebook
"Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
  • By removing the CMOS battery
  • By using the motherboard jumper
  • By using MS DOS command
  • By using software
  • By using Backdoor BIOS password
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
Jan 08, 2011 | Intel DG31PR Motherboard
Computers & Internet Logo
131 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
