Question about GE Dryers
Dryer works but doesn't get hot, takes 2 or 3 cycles to dry t
GE dryer model ddsr475et3ww
  • 709 Answers
The dryer power to the heater has become disconnected. This could be a fusible link, loose connection to the heater, or the heater itself is burned open.
Disconnect the dryer from receptacle and open the top up.
Use a Volt-ohm meter to check continuity using ohms. Connect one lead of the meter to one end of the heater and the other lead to the other end of the heater. It should read some value, not sure of exact value, but a reading indicates continuity. No reading means the heater is open circuit.
If the heater is found th be ok, you need to find what is keeping power from getting to the heater. You have High temp sensor, and should have a fusible link that will open the circuit if the temperature gets dangerously hot. These links are normally embedded near the heater and have a wire connecting on two terminals. Trace back from the heater connection to devices before it to find which device is keeping you from getting power to the heater.
You can order replacement parts from www.repairclinic.com
Posted on Jan 10, 2009
Ge adora dhdvh66ghobb stops heating after 8 minutes
bad thermostat possibly, which will do that
May 05, 2014 | GE DHDVH52GFWW Gas Dryer
GE Dryer model DDE8509R0MWW is getting warm but not hot, takes forever for clothes to dry :(
Check the ductwork for excess lint, kinks, bird nests (yes) or anything else that would restrict the air flow. There is a lazy man's shortcut for electric dryers ONLY: Disconnect the dryer vent and run a load of damp clothes... if the dryer dries the load in normal time, the duct is clogged or kinked. If it doesn't, it's something wrong inside the dryer.
The most common reason for your problem is the cycling thermostat. This is cheap and relatively easy to fix. GE cycling thermostats require turning OFF the power and removing the front of the dryer. It's located on the blower housing. Two wires, two screws. If you have an ohm meter, a good one will read zero ohms.
http://www.repairclinic.com/PartDetail/Cycling-Thermostat/276447?modelNumber=DDE8509RCMWW
The other possibility is the heater element. GE has a dual element. If half of this heater breaks, it takes a long time to dry towels and jeans. Incredibly, GE gets about $200 for these because you can't replace only the heating coil (which was only about $30)... you have to buy the whole unit. This requires removal of the drum. Not impossible for do-it-yourselfers, but it's a challenge for first timers.
Good luck.
Mar 03, 2011 | Dryers
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
My ge dryer model # dcb330gb2wc will not get hot. The clthes tumble but are still wet after a c ouple of cycles
HI. Check the below details to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
Jul 22, 2009 | Dryers
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
85 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
